Engine Bolt Torque Specs-Valve Cover/Head Bolts
11-16-2011, 06:49 PM | #1 |
92
Rep 1,456
I just ordered the parts to do my valve cover gasket replacment (due to leak) and my broken head bolt (next to oil filter housing)
I have searched and read through threads, but I need a definite answer on the torque specs for these bolts. Valve Cover Gasket Bolts: ? Broken Head Bolt: ? The head bolt in question is literally the same bolt as in this thread ---> http://www.e90post.com/forums/showth...ken+head+bolts See post# 20 for the bolt in question. Thanks in advance. |
01-05-2012, 04:14 PM | #4 |
Rep 20
How did the replacement go? I'm looking into doing the same repair. My VCG is leaking and I am looking for a DIY write up. When you started replacing it, did you merely need to replace the bolt, or was the gasket itself crumbling?
01-05-2012, 04:27 PM | #5 | |
92
Rep 1,456
It isn't a priority since it has no ill effects except a slow loss of oil and a burning smell from it dripping on the cats from time to time. I will post results and photos when I get around to doing the job. |
01-05-2012, 04:36 PM | #6 |
Rep 20
I hear ya there! Good luck on the repair. If it is not too much to ask would you possibly take some pictures? I would love to see this process. If not, no worries.
Who says burning cats are an ill effect?? lol, jk. Goodluck! |
01-05-2012, 05:11 PM | #7 |
92
Rep 1,456
Haha yea no doubt. Ill try to document the whole thing. Can't believe no one has made a DIy on here for the issue. I will do my best to make one.
01-05-2012, 09:04 PM | #8 |
***** noob
1372
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
hope these pics can help....please read the 1st paragraph on the 1st/2nd pic!!!!!
When you say "broken head bolt"....I think thats the "cylinder head cover fastener" (5) The valve motor bolt should be (1)....its pretty easy to DIY let me know if you need anything else.
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) Last edited by ska///235i; 01-05-2012 at 10:41 PM.. |
08-08-2013, 02:15 AM | #9 |
Rep 5
Hey guys i really need help. Im almost pretty much done putting all 14 cylinder head cover fastener except for on by the oil filler in front of the timing chain one of the fastener thread hole was stripped due to weak thread when i was about to torque it down. Is there any way i can fix this? Help out
08-08-2013, 02:18 AM | #10 |
Rep 5
I was thinking bout putting a thread inserts to the stripped thread hole. I dont know what size is the thread but the fastener was 10mm. Where can i get this kinda inserts? Any help or suggestion would greatly appreciated.
08-08-2013, 04:22 AM | #11 |
15
Rep 247
Just google the bolt size and you should come up with the correct tap, helicoil insert, and drill bit.
Bilstein+Eibach, UUC F&R sways, Powerflex bushings, PE+Supersprint 2nd cat delete, Euro Intake+Silicone Intake hose, SS Brake Lines
08-08-2013, 12:31 PM | #12 |
164
Rep 401
There is already a DIY on this in the DIY section that covers not only VCG replacement, but replacement of the eccentric shaft sensor as well.
08-10-2013, 09:15 PM | #13 |
Rep 5
Is the helicoil insert does its job? My friend ordered it for me? Has anyone done this? I was just curious and nervous bout drilling and putting the helicoil thread to the stripped thread hole
