Oil Leak back...What can it be?
11-15-2011, 10:10 AM | #1 |
Rep 27
Hi everyone, its been a while since ive signed in. My 06 325i looks to be leaking somewhere. I checked the oil level and I have lost oil. I have small oil drops in garage and smell the burning oil. what can it be? Im going to try and take a look on Thursday. I been reading that it maybe a rear main seal. I would like to know of some people that had have oil leaks and what was the cause.
I've replaced the valve cover gasket on my e90 due to broken bolts.( so if anyone needs info on that I can help). Thanks for the Help. |
11-15-2011, 11:09 AM | #3 |
Rep 27
Thanks will do that. I did change it out on my old E46 and talk about cheap part but hard work. the E90 setup looks easy though. how long did it take you? what signs did you see? on the E46 oil would collect on the middle of the extra screw holes on block. is it about the same?
11-15-2011, 12:36 PM | #5 |
202
Rep 1,950
Drives: 335i
hmm
check the tranny gasket.
11-15-2011, 05:00 PM | #7 | |
1646
Rep 4,877
All the other stuff just leaks from the bottom, but doesn't hit anything hot to burn. |
11-15-2011, 05:40 PM | #8 |
153
Rep 3,730
This. It's also a simple DIY.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
11-15-2011, 05:42 PM | #9 |
153
Rep 3,730
If your Tranny pan was leaking you would notice a puddle underneath it. I would know, just had mine fixed due to leaking. It's another easy fix but the fluid is rather expensive.
11-15-2011, 05:45 PM | #10 |
56
Rep 1,232
Not to mention it would not effect engine oil level. Tranny fluid is a different color, smell and lubricity than engine oil. I just had the oil filter gasket fixed under my last warranty visit at 48700 miles.
11-16-2011, 12:42 AM | #12 |
POGI
143
Rep 1,096
you shouldve have checked around the oil filter housing if theres signs of oil dripping in that area, because this is known for e90. but if changing the valve cover gasket solved it, then good for you
11-16-2011, 08:05 AM | #13 | |
1646
Rep 4,877
Chevy/Ford ones used to be brutal (they were stamped tin). You'd end up twisting it taking it off, or overtightening a bolt that warped the cover. Newer cast aluminum are much better! |
11-16-2011, 01:52 PM | #14 |
Rep 27
sorry i meant to say,i did that job a couple of months back and the leak stopped. im going to look at the oil filter housing but it looks like the oil is coming from the rear.
11-16-2011, 05:46 PM | #15 |
1646
Rep 4,877
11-16-2011, 10:53 PM | #16 |
21
Rep 364
Can u post some pictures? May help in narrowing it down.
Also, a DIY from you for changing the valve cover gasket would help a lot of folks here. I suspect the valvetronic motor removal and re-attachment would be the most painful part- any tips in the DIY will help a lot of us. Thanks. |
11-17-2011, 01:53 AM | #17 |
Rep 11
Hey real talk... Get it on lift or high enough to underneath... You can guess all day long and ask every ones opinion but until you can good look it's all futile at this point...
Rear main seals are a far fetch, rarely if ever go out. If you replaced the valve cover gasket you can always check on your work... Aftermarket gaskets can fail, and if you used an OEM,check for cracks due to over-tightening? The possibilities are endless until you can take the time to get in there... Oh, on another note... If you changed your V.C. you may want to check everything else that you may have touch in doing so... Don't forget to check oil feed lines. |
11-30-2011, 11:08 AM | #19 | |
Rep 27
02-21-2012, 06:01 PM | #20 |
adrenergic stimulation
45
Rep 405
How was the DIY on the oil filter housing gasket? I think I need to do mine.
03-29-2012, 02:04 PM | #21 | |
Rep 27
I think i Might have to replace my rear main seal. Oil Filter Housing Gasket DIY http://www.e90post.com/forums/showthread.php?t=476419 Last edited by whitee90; 03-29-2012 at 02:16 PM.. |
