KW v1 - ET?
11-15-2011, 09:36 AM | #1 |
15
Rep 134
KW v1 - ET?
Hi
I am planning to put KW v1 coils on xi and get another rims and tires in 19". I wanted to go with front 235 and rears 275. What is the ideal rim ET and tire size so it doesnt rub? thanks |
11-15-2011, 11:48 AM | #2 |
171
Rep 3,160
The KW V1 coilovers are a great choice for your xi! They offer you the best suspension has to offer
As for wheels and tires, the ideal set up would be a 19x8.5 et.35 and 19x9.5 et.33. Tires would be a 235/35R19 in the front and 265/30R19 in the rear. The 275 is a bit big, and you also want to make sure your tire rolling diameter between front and rear is within spec. If you need any help, please feel free to ask! |
11-16-2011, 08:18 AM | #3 | |
93
Rep 301
I thought ET35 for both rear/front was ideal for XI? |
11-16-2011, 08:50 AM | #4 |
171
Rep 3,160
If you want to run a squarred set up then yes, that's exactly what you want to run! In that case it would be a 19x8.5 et 35 all around. Many guys run the staggered set up as well. Totally your choice!
11-16-2011, 09:11 AM | #5 |
Rep 169
[QUOTE=**********s;10812767]If you want to run a squarred set up then yes, that's exactly what you want to run! In that case it would be a 19x8.5 et 35 all around. Many guys run the staggered set up as well. Totally your choice![/QUO
Will ET35 flush on the rear? |
11-16-2011, 09:50 AM | #6 |
171
Rep 3,160
"Will ET35 flush on the rear?"
I will PM you with more information! It will be slightly inside the fenders..I'll send you some pictures! |
11-16-2011, 11:14 AM | #7 |
MOE
214
Rep 2,530
x9 + 25 flush
11-16-2011, 11:31 AM | #8 | |
15
Rep 134
What are the differences between KW, HR and Eichbach. Do they all have kits for xi model and if so what is difference in terms of build quality, drive quality, etc? |
11-16-2011, 03:14 PM | #9 | |
Rep 78
I am thinking of getting a set of tires for my rims 19x8.5 et 33 and 19x9.5et 22 as you recommended 235/35/19 and 265/30/19. Any recommendation for tire choices? I am thinking between Hankook V12 or Continental Extreme Contact DW
Thanks Deric Quote:
11-17-2011, 11:35 PM | #10 | |
Rep 169
This is square set up, I am talking about. The differences are ET (offset) front and rear. |
12-02-2011, 07:14 PM | #12 |
21
Rep 415
Drives: 2011 335i X-Drive Sedan
I run 235 front (8.5 rim) and 265 rear (9.5 rim) with et35 all around and have not problems. I believe this is within spec as well. I was thinking of adding a 10mm - 12mm spacer to the front to improve the handling and reduce the understeer. I've heard this helps but have not tried it myself.
2011 335 X-Drive E90 MTECH 6MT • AST4100's • Vishnu 3.5" DP • Helix FMIC • Procede V5 • M3 Strut Brace • M3 Trunk Lip • LUX H8 • 19" Alufelgen SF-71: 8.5' front, 9.5' rear • Continental ExtremeContact DW Tires
