E92 330i- jerking during 'spirited' driving
11-14-2011, 02:13 PM | #1 |
Rep 74
Hi, im encountering a strange problem with my E92 when driving fast. After maybe 2 or 3 minutes of hard driving the car will jerk forward for a split second when i let off the throttle each time, for example when coming into a corner. (The car is a manual by the way) Its as though there is a delay from when i let off the throttle and the rest of the car responds. Is this down to the car being rear wheel drive and the delay is all in the drivetrain?
The car drives perfectly during normal driving, and will return to being smooth after ive been driving it hard almost imediately when i begin to accellerate more gently and change gears at lower rpm. Anybody have any experiance of something like this happening to there car? |
11-14-2011, 03:02 PM | #2 |
213
Rep 1,780
It's normal I think it has something to do with the ecu adapting to driving styles
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
