DIY windshield washer filler pipe replacement??
11-13-2011, 07:28 PM | #3 |
17
Rep 363
I think you have to remove the engine and the drivetrain.
JB4, BMW Perf. Exhaust, DCI, Strut Brace, KW Series 1, Quaife LSD, Black Kidneys.
11-13-2011, 08:18 PM | #4 |
124
Rep 1,151
Drives: 10 e90 335i
Nope, just have to remove the tire, fender liner, washer tank and then replace the hose. Don't forget to get new plastic rivits to replace the ones you have to cut off. Or you can opt to leave them off if you'd like. Just leaves a bit of a gap but not a huge concern.
JB4, DP, VMR V710, Sonic Tuning S1 coilovers, Hybrid Ovations, Soundsplinter 10" and Zapco DC Ref amps |
11-14-2011, 12:22 PM | #5 |
10
Rep 126
Drives: 2006 325XI Wagon
How do you know you need a new hose? My tank does not hold fluid, but I have not looked into it enough to know if it is a crack in the tank, a bad hose, or a bad seal somewhere.
11-14-2011, 12:31 PM | #6 |
201
Rep 288
I too ran into an issue with my tank not holding fluid.
Mine was leaking from this pic below and it ended up being the washer pump that was leaking, not the tank or the hose. |
11-14-2011, 12:40 PM | #7 |
10
Rep 126
Mine looks like it leaks in a different location. It is more towards the front of the car.
11-14-2011, 07:09 PM | #8 | |
Comfortably Numb
578
Rep 654
Drives: '18 x1/'13 X3/'06 330i
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada 18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec |
11-14-2011, 07:13 PM | #9 |
Comfortably Numb
578
Rep 654
Our 2006 325i leaked washer fluid at the front of the car. Dealer replaced leaking nozzles in the headlight washers.
01-23-2012, 08:35 AM | #10 |
234
Rep 1,491
Has anyone had any updates or news on this thread? This weekend I discovered that the tube that goes to the reservoir tank is CRACKED and need to replace on my own. Any help would be much appreciated...
01-26-2012, 10:12 AM | #11 |
10
Rep 126
I have not done anything with mine yet. Mine will hold a little fluid, but I cant fill it up too much or some spills out. Its just to cold these days to be in my garage during the weekend.
11-07-2012, 09:47 AM | #13 |
20
Rep 244
my filler tube has a crack in it but its near the very top just below the black fill cap... think it would be a problem if i just used some 2 part plastic epoxy to seal the crack up instead of going through all the steps to replace the actual pipe?
11-07-2012, 09:54 AM | #14 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
my top kept popping off and the fluid would evaperate. had tom strap it down.
11-07-2012, 06:39 PM | #15 |
Resident Septuagenarian
23
Rep 388
Who is tom???
Johnny
Sent from my keyboard using hunt and peck... |
