OK to get 2005 build date e90?
11-13-2011, 04:56 PM | #1 |
50
Rep 753
I'm looking to purchase an '06 325i but it was built in 06/2005. Anything I should be wary about?
I know that usually within the first 6-8 months of a new model being released there are usually some changes made to the car's build, some fixes, and changes in the packages available that comes with it. Usually quality control stuff from my previous experiences with first model year BMW's. Also, anyone know if e46 Type-55 16" wheels will fit on there? (my existing winter rims/tires) |
11-13-2011, 05:07 PM | #2 |
17
Rep 329
BMW pretty much had things nailed down by the time the E90 came about because they were already tested on the 5 car. The only issues are the control lock which sometimes locks up and u can't start the car do a forum search. Second known issue is watter pumps going out at 80k miles i also had an AC compressor go out at like 45k..
other than that BMW built a solid car considering it was the first batch. Also take pride in the fact that you have the last 325 end of a generation
2007 328 Jet black||M3 rear bumper|LED license plate|220M 19's staggered|Redlines|carbon fiber wrapped interior|
11-13-2011, 07:53 PM | #3 |
Comfortably Numb
578
Rep 654
Drives: '18 x1/'13 X3/'06 330i
We currently have a 06 325i with 73,000 miles (07/2005 build date). No real problems other than leaking headlight washers @ 52,000 miles, noisy ac/heater fan @ 60,000 miles, and a water pump @70,000 miles. Pixels fading on the radio has been another known issue also. Really has been a solid car.
Your existing rims may not work on the e90. e46 Style 55 typically ran 225/50/16 tires mounted on rims with with ET-46mm offset, e90 typically is ET-34mm offset on a 16" rim with 205/55/16 Tires
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada 18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec |
