FS: 3 Series Winter Rim Tires Balanced TPS Rial Como + LM-22
11-13-2011, 02:19 PM | #1 |
12
Rep 244
Purchased from Tire Rack - original invoice available $2,127. 4 - 17x7.5 Rial Como Bright Sat 4 - 225/45R 17 Bridgestone Blizzak LM-22 RFT Runflat OE Vehicle 4 - Hunter mount and balance 4 - 433MHz Tire Pressure sensor and steel valves Used three winters on a 328xiT - total 20,000km (13000 miles). Should be good for another season or two. Southern Ontario (Burlington/Oakville) area. Asking $600 or offer |
11-13-2011, 03:32 PM | #2 |
Ex-Diesel Driver
63
Rep 2,000
Can you get these to the border/Windsor? Are these the new sensors compatible with LCI? Please confirm offset and that they are square set up.
FS: HRE Center Caps http://www.e90post.com/forums/showth...post13972317l] |
11-13-2011, 07:07 PM | #3 | |
12
Rep 244
They are a square setup. No offsets as far as I know they were the same size as the OEM setup. As indicated they were used on a 328xIt. They are in good shape. One wheel has a couple of small rash marks. I guess they could be delivered to Windsor - but I am not sure if that would be worth the delivery charges. We are about 3-1/2 hours from Windsor. |
12-03-2011, 11:03 AM | #5 |
12
Rep 244
