How bad is launching 2nd gear?
11-13-2011, 12:27 PM | #1 |
149
Rep 3,552
had an argument with a friend last night about launching in second gear.
being that i have a 6AT, 1st gear is kinda useless with these crappy allseasons. and 2nd in my opinion feels like it could be a better launch. From e90post i see alot of people who drag their cars do this. but my friend said it one of the worst things you can do for your torque converter. all the stress is going to the torque converter and all the heat. basically.... 2nd gear launch ok? |
11-13-2011, 01:48 PM | #2 | |
55
Rep 3,606
11-13-2011, 01:54 PM | #3 |
Captain Crunch
168
Rep 548
Shouldn't be a problem, the Diesels launch in second due to the torque. Honestly though, you should just leave it in D and let the car do its thing. If you are losing traction on your all seasons, you are either flooring it with the DSC off or have bald tires.
On Order (in transit): BMW iX 50, Oxide Grey
Retired: BMW Welt Delivery 4/14/16: European Delivery - 2016 340i EBII/Saddle - ZMP | ZCW | ZDA | ZLP | ZTP | M Adaptive | Rear Shades | MPPSK Before and After Dyno Retired: 2011 335D Space Grey/Black - ZSP | ZPP | ZCW | 6FL | Sat Radio | Nav | $600 Base Audio Upgrade |
11-13-2011, 01:55 PM | #4 | |
55
Rep 3,606
In AT, if there was damage being done the tranny would shift. |
11-13-2011, 02:16 PM | #5 | |
27
Rep 1,110
A torque converter sits between the engine and the transmission input. It can only ever see a worst case of maximum engine torque and zero rotational speed of the transmission's gear train. It is rated to withstand that maximum torque difference between engine and transmission. Once the vehicle starts moving forward, the TC is no longer in full stall, and the frictional heat rate reduces noticeably. What WOULD be bad for the driveline would be an extended brake stand, i.e. application of full brake while simultaneously applying full throttle. THAT is what would heat the transmission fluid unnecessarily, and if done for too long a period (several tens of seconds, for example) then the transmission fluid temperature can rise above normal operating limits. Repeated often, this type of treatment will cause the transmission fluid to lose its protective properties and damage to the transmission may result. Given how sensitive car makers are to litigation, it is unlikely (read they don't) that an auto maker would allow transmission programming that would damage the transmission. If the diesels can withstand 425 ft-lbs in 2nd (or any gear, for that matter), then there is no reason a 335i AT can't tolerate 300 ft-lbs in 2nd... Regards D.
2016 GLE 350d - White on Black
11-13-2011, 02:46 PM | #6 |
1646
Rep 4,877
Considering driving in "D" ALWAYS launches in 2nd gear, you won't have a problem.
You can search for it, but a lot of guys say you get better ET's in 2nd gear. I'm guessing the PCM does more "granny protection" in 1st. Could also be that the engine ends up hitting the sweet spot in 2nd faster (like a car with a high stall converter), so better launches. |
11-13-2011, 04:49 PM | #8 | |
50
Rep 753
However, keep in mind that the gear ratios and final drive are different on AT vs MT. |
