M3 Steering Wheel Installed- Paddles NOT Working!
11-12-2011, 07:37 PM | #1 |
36
Rep 200
Drives: 2011 335i
New M3 w/DCT paddles installed tonight. One problem... the paddles aren't working? Post up if you have any possible solutions. Sport wheel with paddles came off the car. New wheel came with paddles installed and harness/wires. Did I forget to do something? Buttons work!
'11 335i - Alpine White/Black Dakota/Carbon
Sprt, Prem, Nav l 19" Avant Garde M310's- Matte Gunmetal l Black Grills l M3 Wheel w/LCI Paddles l M Spt l BMW Perf Rear l M3 Spoiler l Cyba 4" Blk Chrm tips l AW refl l Tint l GP Thunder 8500K l Stop Tech Rotors l Perf Shiftr/Boot l BMS JB4 Stage 2 |
11-12-2011, 07:39 PM | #2 |
10
Rep 131
Just wanted to say, Beautiful wheel! But yeah, there has to be a missing connection for the new paddles.
Dinan Stage 3 | High Capacity Oil Cooler | High Performance Intercooler | Carbon Fiber Cold Air Intake | Carbon Fiber Strut Tower Brace | Rear Sway Bar | KW V1's | 18" Forgestar F14's
11-12-2011, 10:10 PM | #4 |
147
Rep 2,383
The paddles are smarter than you think. They know where they are. Now you just have to buy an M3, move the wheel into that car, and the paddles will work fine.
Speakers: CDT Audio HD-42 comps--front doors (RAAMmat deadened), CDT ES-06 6.5" woofers--kickpanl Pods, Hertz EBX202R dual 8" ported trunk sub. Amps: Phoenix Gold RSd 500.4 (comps & pods). PG RSd 600.1 (sub). Power & Ground: 4AWG Streetwires w/RockFosgt RFDB1 distro blocks. Input: HU lineout--Kicker KISL RCA adapters--RockFosgt RFIT-6 cables--Audiocontrol Matrix--Monster cables--RSd 500.4--lineout Monstr Cabl to RSd 600.1.
6ixSpd6015.50 |
11-12-2011, 10:16 PM | #5 |
36
Rep 200
Drives: 2011 335i
Yes, they're connected.
11-13-2011, 12:53 AM | #6 |
262
Rep 5,018
Drives: VALNCYA
11-13-2011, 07:13 AM | #7 | |
112
Rep 2,856
Drives: 2011 335is E93
Would there be an extra harness/connection within the M3 that connects to the main that you might be missing? Dunno, seems weird not to work if it's a direct bolt-on. |
11-13-2011, 09:26 AM | #8 |
50
Rep 825
Drives: a car.
paddles are not interchangeable.
if your car had SSG paddles and you added SMG or LCI its not just plug and play. if this is what you did, you can get it to work. what type was on your car before?
11-13-2011, 02:11 PM | #9 | |
36
Rep 200
Drives: 2011 335i
Anyone know if the LCI paddles fit the paddle hole in the new M3 wheel? Save me some time disassembling if you know please.
11-13-2011, 05:59 PM | #10 |
50
Rep 825
Drives: a car.
the SSG, LCI and DCT paddles are different, as you stated. The LCI ones have a resistor in them, and lack the third wire.
you will get this sorted out but its above my pay grade. we need to get the resident paddle expert on this, im certain he'll set this straight. im going to PM 1QuikWS6 with a link to this thread hopefully we'll hear back.
11-13-2011, 08:13 PM | #11 |
112
Rep 2,856
This is some good info. I too will be looking at getting nice lil upgrades like an M wheel. This preliminary info is nice. I know what to watch out for now. Thx
11-13-2011, 08:19 PM | #12 |
36
Rep 200
Drives: 2011 335i
Someone out there has got to know how to make these work on the LCI car...
11-13-2011, 08:53 PM | #13 |
50
Rep 825
Drives: a car.
in the interest in showing you the differences check out these two pictorials from the DIY located here...
http://www.e90post.com/forums/showthread.php?t=600729 when Quik gets back to us he'll know definitively
11-14-2011, 02:08 AM | #14 |
No 55mph
1622
Rep 8,476
IDK what kind of DCT paddles you have, but they only have 2 wires - not 3...
The SSG paddles that can upshift/downshift on each paddle have 3 wires - (1) for upshift signal, (1) for downshift signal, (1) for ground DCT paddles that upshift one side/downshift other side have 2 wires (1) for either the upshift or downshift (depending on side) and (1) for ground. Basically, all these paddles are just completing a circuit to ground in order to complete shift. Check your DCT paddles again and tell us whether there are 2 or 3 wires coming off them. LCI paddles definitely need to be modified to work on pre-LCI cars, don't know at this point whether their MFB are also different. Really not too much that can be different as the MFB simply pass the paddle signal thru to the wheel side of the slip ring. Post up pics of the DCT paddle wire connectors showing number of wires and Pin #'s they are connected to in the end plugs & pics of the original LCI paddle wire connectors showing the same detail. It may be that you simply have to swap what terminal the wires go to on the DCT connectors to match what the LCI have... As a test, you could manually wire the DCT paddles as per the 1st diagram above from B-737 for M3 DCT (essentially bypass the MFB & go directly from paddle connector to black connector at wheel side of slip ring). If that still doesn't work, there has to be another wiring difference from backside of wheel slip ring on LCI cars vs pre-LCI cars
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
11-14-2011, 02:58 PM | #15 |
No 55mph
1622
Rep 8,476
Without having any pics - check this 1st:
Look at the black connectors on ends of your original LCI paddles, should be (2) wires. If you look real close on the black connector, there are numbers on the pin connections 1 thru 3. Take note as to which slots the LCI wires are in (i.e. 2 & 3, 1 & 3, 1 & 2, etc) Then go look at the new DCT paddle connectors - again, should be (2) wires. See which slots those wires are in. If they are NOT in the same slots as your LCI paddles, then use a tiny screwdriver to push in on the locking tab of the metal pin on end of wire that is inserted in black connector while pulling on the wire at the same time to remove. Then push the metal pins back into the black connectors in the same slots that the wires are in on the LCI paddles. If the wires on the DCT paddle connectors were NOT in the same numbered slots as the LCI paddles - that is the problem. Putting them in the correct numbered slots to match LCI paddle connectors should fix the problem. If this is not the case, and the DCT paddles are in same slots as LCI paddles - then get back to us and we'll try something else...
11-14-2011, 04:11 PM | #16 |
15
Rep 356
it wont work, and your DS should not be working as well.
for 2010 and before cars, ssg/dct paddles are just completing a circuit to ground in order to complete shift. Thats why by removing the resistors from lci paddles, they have the same functionality as ssg/dct paddles and will work on 2010 and before cars. for 2011 cars, lci paddles are not connecting to grand anymore (no pin#2), and resistors are connecting between pin#1 and #3. To make the dct paddles work on 2011 cars, I think the missing resistors need to add back to dct paddles in order to have the same functionality as lci paddles. I am working on add resistors back, will report after I finished. |
11-14-2011, 04:24 PM | #17 |
15
Rep 356
to op, the lci paddles will fit on m3 wheel, you can put on your original paddles and they will all work. Save you some time to make dct paddles working and sell them.
11-14-2011, 04:38 PM | #18 |
36
Rep 200
Drives: 2011 335i
I've got both wheels apart and pics of both below...
Points to clarify:
Question- According to post above, should I move the solid Gray wire to position 1? Anything else you notice from the pics?
11-14-2011, 04:40 PM | #19 | |
36
Rep 200
Drives: 2011 335i
Is the above a guess or something you know to be accurate for the 2011 LCI model? See Wanlong's post above.
11-14-2011, 04:42 PM | #20 | |
36
Rep 200
Drives: 2011 335i
All- I really appreciate the help, but if you're guessing vs. you've done it then please don't post up. My car's in pieces and this is taking a lot of everyone's time. Again, appreciate the try!
11-14-2011, 04:51 PM | #21 | |
50
Rep 825
Drives: a car.
wire them into the slip ring connector directly. I have a 2011, i did this and it worked. Pin #4 and into pin #6. send the other leads to ground. the pins your remove, tape them up.
11-14-2011, 05:39 PM | #22 |
36
Rep 200
Drives: 2011 335i
I just swapped my LCI paddles off of my sport wheel for the M paddles on the M3 wheel and they fit perfectly. The tabs lined up and the screw hole is perfectly lined up. DONE!
I don't use the paddles enough to worry about which ones they are, I just wanted them to work. I now have a brand new set of M paddles for sale! Thanks to all who provided input!!!
