e90 xenon lights flickering
11-12-2011, 02:24 PM | #1 |
218
Rep 2,702
i tried looking it up, couldnt find the solution to it. But basically yesterday as i was driving with my headlights on my pre lci e90, the passenger headlight starts flickering and it goes off and back on. any solutions to this issue? Do you guys know whats going on? oh and i installed mtec angel eyes awhile back so that might be the case
Cars: SGM 325i l BSM 135i l SS to Gloss White S2000 l Arctic White RS4 l White GTi l AW 335d M-Sport l IS 350 l e92 M3 l F80 m3
11-12-2011, 02:52 PM | #2 | |
1646
Rep 4,877
Is it repeatable? Best bet would be to swap the driver/passenger ballast to confirm. It won't be the bulb, since it still lights (HID bulbs don't have a filament inside.). BMW does use some sort of bulb failure detection thing on other lamps (not sure if the HID's use that), so that could be the issue as well. Swapping the ballast would confirm. My Acura had one just die. I ended up JB welding a generic one off ebay. Acura wanted $800 for it, Ebay generic one was $60. |
11-12-2011, 02:54 PM | #3 |
Rep 61
Ballast is probably going bad, you'll have to get a new bulb. Get them off ebay or they will be $80 plus each. I got an oem set for that, replaced the bulb, no more flickers.
11-12-2011, 03:12 PM | #4 | |
218
Rep 2,702
so how would i replace it??
11-13-2011, 09:27 AM | #5 | |
1910
Rep 3,218
Drives: 2018 BMW 440i GC
Any more info from the guys who have done this is appreciated. Links to DIY for bulb and ballast replacement - it seems like Ft Knox for these headlights? PS my car is pre-face e90 too (not my signature) |
11-13-2011, 10:58 AM | #6 | |
218
Rep 2,702
nah no indicators come on
11-13-2011, 11:19 AM | #7 | |
158
Rep 3,158
Here's some extremely useful info about HIDs:
http://en.wikipedia.org/wiki/Metal_halide_lamp And the relevant piece of that article: Quote:
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
11-13-2011, 02:50 PM | #8 | |
1646
Rep 4,877
I'd still recommend swapping L/R side components to confirm though. I wasted $100 on a new lamp for my Acura, and that wasn't the problem. |
11-13-2011, 04:32 PM | #9 |
218
Rep 2,702
for sure im gonna give that a try. so does anyone know how to remove the ballast or the light? any have a DIY?
11-13-2011, 05:44 PM | #10 |
1646
Rep 4,877
I don't know how to get the BMW ones out.
Little FYI though: Don't touch the bulb with your bare hands. The oils from your fingerprints can cause it to shatter. Ballast puts out a boat load of voltage, so just be careful around the HV lead that connects to the bulb. |
11-13-2011, 06:03 PM | #11 | |
218
Rep 2,702
11-13-2011, 08:22 PM | #12 |
Rep 61
You have to access them thru a small removable panel in the wheel well. Depending on which side, steer the car so the tire goes inside the well, or you can remove the wheel. There is also a waterproof cover over the back of the headlight assembly, comes off after releasing a few tabs. Its not real easy the first time, but doable. The drivers side is a #@##$% as you have to remove the airbox assy first. The bulb and ballest have a wire tab that holds it in place.
11-13-2011, 08:56 PM | #13 | |
218
Rep 2,702
you mind making mea DIY for me?
11-13-2011, 09:00 PM | #14 |
158
Rep 3,158
As in, with pictures and everything?
--Mark Twain |
11-13-2011, 09:09 PM | #15 |
218
Rep 2,702
11-25-2019, 12:32 AM | #17 |
Rep 1
I have got E90 2008. A few months ago, my left headlight started flickering, I googled and read different threads on various forums. Many pros were suggesting bulb swapping so I did that, but it didn’t work for me. I decided to replace the ballast and purchased a new one from an online store. I changed the ballast and now the problem has gone. I would suggest you guys not to spend money on replacing the bulbs just change your ballast to get rid of flickering. Here is the product I am using
https://www.xenonplanet.com/mitsubis...n-ballast.html |
11-25-2019, 05:26 AM | #18 | |
654
Rep 1,893
OP, you'll just have to roll the dice on this one. |
11-27-2019, 05:53 PM | #20 | ||
218
Rep 2,702
11-28-2019, 05:43 AM | #21 |
654
Rep 1,893
