Qs on head lights!!!
11-10-2011, 01:58 AM | #3 |
1312
Rep 10,185
They are the "flash to pass" lights
You need to pull the light stalk on the steering wheel back to flash them
BMW if you are reading, I need a job, Please. |
11-10-2011, 06:15 AM | #4 |
Where'd my VTEC go?
481
Rep 6,067
they are not flash to pass. they are cornering lights. they will turn on at low speeds when you turn or have your signal on. or both will turn on if you are in reverse.
11-10-2011, 06:28 AM | #5 | |
Big Beaver Smile
2101
Rep 3,791
OP you can drive around in reverse all of the time so they will both always be on.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
11-10-2011, 07:04 AM | #6 |
1559
Rep 4,109
Drives: BMW M3
Yes they turn on at low speeds when you use the turn signal and if you turn the wheel a certain amount I believe. It's pretty neat.
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
11-10-2011, 08:50 AM | #8 |
Rep 82
yes but that only works when the lights are in auto mode, which these pictured can not be in since the healights are not on? i have seen other e92's with these on. i believe it can be done as drl?? not 100%, but have seen angels and those only while driving.
11-10-2011, 12:33 PM | #9 | |
Rep 116
wondering how |
11-10-2011, 12:40 PM | #10 |
Semper Fi
23
Rep 417
Drives: E60 ///M5
i was in ur spot man.. it looks like they are always on but since our angel/halos are so bright they look like they are on when they are not.. i thought at first they were day time running lights but its true they only turn on when going in reverse or turning..
11-10-2011, 12:47 PM | #11 |
124
Rep 2,554
Aren't they the day time running lights too?
11-10-2011, 03:33 PM | #14 |
Rep 116
just attached another pic, see thats very bright.. but i never see my car's light turns like that...
