2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums CANADA Style 184 winter rims
      11-08-2011, 03:55 PM   #1
kmac1980
35
Drives: '19 540xi
Will the winter package for previous 5 series and 6 series with style 184 18" rims and 245/45/18 RFT work well on the F10 535xi?
      11-08-2011, 06:11 PM   #2
bobblehead
bobblehead's Avatar
256
Drives: warp speed
those are 18 * 8 ,Offset 20
The ideal is 18 * 8,Offset 30
Both using 245/45/18 tire
Meaning, you will have extra 10mm clearance from the Strut, in turn the rim will now extend 10mm outward. Technically, it's okay. However there is a very small chance your tire may rub into the fender as the suspension goes up & down.
      11-08-2011, 06:21 PM   #3
CrunchTime
11
Drives: 335xi e90 / 535xi F10
There appears to be 2 offsets available on style 184s. 18x8@20mm offset and 18x8@14mm offset. If they are 14mm, they might be too aggressive for the F10s.
F22 M240i xDrive
Retired: 535i xDrive (F10) | 335i xDrive (E90) | X5 4.4i (E53) Sport Type87 20" | 540i (E39) ACS Type III's |M3 (E36) Dakar yellow Hamann PG1 | 325is (E36) ACS kit & Type II's
      11-08-2011, 06:47 PM   #4
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Agree. If you have the latter which are found on the 6 series, then the likely it will rub against the fender is very high.
The difference between (ideal) 30 - 14 = 16mm more clearance from the struct and the wheel is extended 16mm outward.
I guess the OP needs to find out which version of the wheel you have.
      11-09-2011, 08:23 AM   #5
kmax1980
Drives: 08 E93 M3 Jerez Black/Fox Red
thanks for the info guys.... aren't stock wheel/tires specs VERY conservative? I mean I am running 15mm/12mm spacers on my e93 M3 and there are no clearance issues, however I guess there is only one way to find out!
      11-22-2011, 04:36 PM   #6
CrunchTime
11
***Pics removed as sellers on kijiji started using pictures of my car without consent.***
FYI, I came across a set of OEM 184s on Kijiji 18x8@14ET with 245/45/18 Pilot Alpins. Front offset is a bit too aggressive but rears sit flush. They work fine on stock 535xi height without rubbing. Hope this helps.
F22 M240i xDrive
      02-03-2013, 04:41 PM   #7
jimaras
Drives: E60 523i
can i put all season tyres on those rims? because they are in the bmw winter package for the e60 and i haven't seen anyone put all season tyres, only winter tyres
thank you
      02-04-2013, 12:53 PM   #8
jimaras
Drives: E60 523i
anyone???
      08-08-2018, 02:10 PM   #9
The TRG
Drives: 2016 340ix Black Sapphire
Bringing this thread back from the dead!!
I have an ‘11 535xi with 20 spoke oems. I am looking at a set of style 184 just like what is pictured above. They are 18x8 offset 14... which means a mm outward of 16mm.
Does anyone have input if this will run ok with my car? All suspension and ride height is stock.
The second to last post in this thread stated that someone saw a car with that wheel and style and fit without issue. So I’m curious if, in the years since, this has been a popular style on 535’s.
Originally Posted by jimaras View Post
anyone???
Tags
style 184
5post
