BMW firing with no codes
11-06-2011, 01:43 PM | #1 |
40
Rep 413
Car was running fine, next day weather was cold in the 30s, starting it up and car was studdering, drove down the street and got CEL P0304. Found out that misfiring in cylinder 4. I replaced all spark plugs and car started it up and car still hick up with same P0304 code. I swapped coil 1 and 4 to see if the code will change to misfiring on cylinder 1 to confirm its the coil pack that's gone bad. Start car up and car idled a lot smoother, but when I gave it some gas, the car would studder/shake more. It's not throwing any codes. Any help or suggestions?
11-07-2011, 06:31 PM | #2 | |
24
Rep 75
Same thing happened to me. I replaced Coils 1 and 3 and it worked fine again. You migh want to get a new or good coil and start mixing them around and pay attention to which one it start shaking at. Make sure you remember where the good coil came from. Good luck |
11-07-2011, 06:51 PM | #3 |
39
Rep 1,558
You need to get the car diagnosed, just replacing parts and hoping for the best is expensive. You could have a vacuum leak, bad injector, no compression (highly unlikely) and the list goes on. Just remember a misfire is not always ignition related.
Sport pack, JB3, Dci, factory oil cooler, 18" M3 reps, Michelin PSS, painted trim, black grills, smoked side markers, LED plate lights, H&R coils, Borla catback |
11-07-2011, 07:12 PM | #4 |
40
Rep 413
Thanks guys! I swapped the coil to different cylinder and got another code confirmation for that cylinder confirming its that code but just to make sure I swap that same coil over to another one and got another code for that cylinder so its confirmed it is that coil. I went to BMW and bought a coil and replaced it and its up and running smooth Thanks!
