exterior bulb out yellow on IP -occassionally
11-05-2011, 04:19 PM | #1 |
ahat
1036
Rep 2,592
i am getting a perodic instrument panel yellow for a exterior light that has failed but all seem lit. Is there a btech menu that displays lighting errors - i couldnt find anything obvious
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
11-05-2011, 05:17 PM | #2 |
Some dude
92
Rep 1,780
Check when dark outside. The light control logic is smart enough to use an adjacent bulb when other bulbs fail. Check angel eyes, tail lights, brake lights, reverse lights, fogs, etc. Make sure the left and right sides look the same. Also many LED angel eye replacements can set occasional faults. Also there is a TSB for faulty rear tail light bulb carriers on coupes and convertibles. The replacements are only $16.50 from GetBMWparts.com. Faulty carrier can cause bulb faults even though they may still light up or the bulbs may not light up even when replaced with new bulbs due to faulty contacts.
RRT
E92 335i/6MT with stuff and things |
11-05-2011, 05:47 PM | #3 |
ahat
1036
Rep 2,592
all corners look identical, same as when fault is not present.
in the first few months i owned it, it did have an defective tail light. covered by warranty. will try to find tsb. thanks
11-05-2011, 05:56 PM | #4 |
Some dude
92
Rep 1,780
Oh and make sure you use German-made Osram bulbs. Many store-bought bulbs don't have the exact same conductivity and can throw faulty bulb codes even if they're good. This is very common on E39 and E46s where people use cheap brass base bulbs instead of Osram nickel base bulbs.
RRT
11-05-2011, 06:13 PM | #5 |
60
Rep 2,334
It can also sense when bulbs are about to fail. Few weeks ago, my dash kept telling me that the rear bulb failed.. but was actually still working. Few days later the bulb failed.
You can use the stalk to find out which particular bulb is giving error. Go to Check Control -> Highlight the error -> hold the stock button for a few seconds, then it will give you a CC-ID#. Google the CC-ID# to find which bulb it is. |
11-05-2011, 09:14 PM | #6 | |
Some dude
92
Rep 1,780
RRT
11-05-2011, 09:17 PM | #7 |
1646
Rep 4,877
I had a similar issue. Turned out it was a park light that's in the light on the trunk lid. I'd flip up the trunk, the filament would touch, bulb worked. Drive it a bit, bump failed, got a error light.
