TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > e90 is hitting 60k within this month
      11-05-2011, 03:24 PM   #1
Speedle
Speedle's Avatar
Drives: 2006 330I Sports
Hey hows it goin, my 06 330i sports package will hit 60k this month and i have no more warranty, just wanted to know what maintenance is needed to be done? i will be heading out to the shop this month, wanted to know what i really need before they try to rip me off with this bs.
thanks in advance
      11-05-2011, 03:29 PM   #2
///M3NACE
///M3NACE's Avatar
168
Drives: E36 M3, E36 Vert , E90 N52
Did you do any work done at 50k?
      11-05-2011, 11:22 PM   #3
Speedle
Speedle's Avatar
Bmw did an oil change before my warranty ended at 496xx miles thats about it
      11-06-2011, 01:47 AM   #4
Glim
21
Drives: 2006 330i & 2013 X5 35i
Same year, car and mileage as you, I changed my Diff and Manual trans fluid and I can safely say that changing the transmission fluid every 50k miles is worth it and would safely change the diff fluid at 100k.
Ignore until it fails or posts a fault code: Water pump, fuel filter, O2 sensors.
If they tell you your water pump is failing please replace it, it just dies, there is no limp mode, you are literally stuck wherever the pump dies, the pump posts fault codes before it dies but does not light up the service engine soon light, which is just wrong.
Change accessory drive belt and coolant hoses when they start to fray/leak/fail.
Check this maintenance schedule out:
http://blog.bavauto.com/9906/bavaria...nce-schedules/
      11-06-2011, 06:15 AM   #5
ENINTY
173
Drives: 2006 325i Sport
Your air filter is in need of replacement at intervals of every third oil change (OCI per BMW CBS), which is about every 55,000 miles. Plugs, trans, diff, and coolant are all at 100,000. There is no fuel filter to replace - it is built into the fuel pump in the tank. The car will tell you the rest.
Also search. There are hundreds of threads on the subject of maintenace.
      11-06-2011, 08:29 AM   #6
Speedle
Speedle's Avatar
ok cool, thanks guys, i keep this is mind and get my diff, trans, oil changed this month when it hits 60k!
i believe my micro air filter was changed around 45k miles by bmw, i will check my iDrive maintenance again though.
      11-06-2011, 09:57 AM   #7
Tom K.
Tom K.'s Avatar
Drives: '07 328iT, '13 Boxster
While this is probably advisable, the only BMW recommended maintenance at 60k is the same Inspection you had done at 30k. Check your 30k receipt for a printout of the 30 or so checks which are done.
While I haven't had this service out of warranty, I suspect it will involve 1~2 hours of labor with very few parts, if any.
Tom
      11-06-2011, 11:52 AM   #8
e90pilot
Freight Dawg
e90pilot's Avatar
Drives: E90 325i
Keep an eye on the suspension bushings and shock mounts and well as engine and tranny mounts. I have 167k on my car. The engines just flawless (knock on wood) but anything made out of rubber is at risk. I changed my front control arms, tension rods and rear upper shock mounts. My tranny guibo is dried up and cracking, my oil pan and oil filter housing gaskets are leaking, and the PCV hoses are cracking (already replaced one of them).
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors
      11-06-2011, 01:41 PM   #9
Turkeybaster115
74
Drives: 335I
thanks in advance
Just push fluids
-transsmission
-brake
-differential
-coolant
-power steering
You could also do a battery check. Oil filter housing gasket will need changing.
      11-07-2011, 09:49 PM   #10
Speedle
Speedle's Avatar
5w-30 synthetic oil, right? havnt had time to look under the hood too see what oil it takes
