Coding for tire/wheel change
11-04-2011, 06:26 PM | #1 |
Rep 75
SIZE change. Is it possible? Google/forum search came back empty.
11-05-2011, 08:11 AM | #7 |
369
Rep 8,693
Drives: 06 330i
you dont need to re code anything for changes in size....
11-05-2011, 09:31 AM | #9 |
369
Rep 8,693
Drives: 06 330i
i guess the jeep guy in me would say to change the speedometer gear, but no coding can fix that for you...
11-05-2011, 09:52 AM | #10 |
342
Rep 1,325
11-05-2011, 10:03 AM | #11 | |
124
Rep 5,627
2. Calculate the percentage difference in tire revs per mile between your old & new tires. 3. Add step 1 to step 2. 4. This will be your new speedometer error. For example, if your speedo currently reads 3% high - a not uncommon BMW error - and your new (larger) tires will have 1.8% fewer revs per mile, then your speedo would then be 1.2% high (3.0+(-1.8)). I'd also advise confirming this with a GPS. So the only "coding" is done by the driver. Tom Last edited by Tom K.; 11-05-2011 at 09:26 PM.. |
11-05-2011, 10:37 AM | #12 |
1571
Rep 29,203
What size are you planning on?
11-05-2011, 10:59 AM | #14 |
369
Rep 8,693
Drives: 06 330i
11-05-2011, 03:11 PM | #15 |
422
Rep 8,003
Drives: '08 E90 335i, '99 E36 M3
There's a way to do this via coding but there are side effects related to cruise control.
11-05-2011, 06:20 PM | #17 |
121
Rep 1,568
The BMW speedo normally inflates the speedo value vs true speed.
So unless you plan on putting 13" wires, any reasonable upsize should be fine. Just confirm with a gps unit. |
11-06-2011, 09:10 AM | #19 |
Rep 189
use this tool to calculate the change in speedometer reading with different size tires:
http://www.miata.net/garage/tirecalc.html |
