New Winter Wheels
11-04-2011, 12:05 PM | #1 |
9
Rep 79
New Winter Wheels
What do you guys think? Its weird seeing the car on 17's, but it rides pretty well. These are no-name wheels, 17x7.5 with 225/45 tires.
They look awkwardly small from the side/rear. Time to get spacers? What size spacers do you guys think I can fit on there? |
11-04-2011, 12:33 PM | #2 |
207
Rep 3,175
WOW, for 17's they actually look pretty good! Without knowing the offsets and based on the pictures alone the fronts don't look that bad, probably could get away w/a 5mm spacer and rears it looks likey you could get away with a 10mm spacer. You could likely use the same spacers with your factory set-up without rubbing issues.
11-04-2011, 12:43 PM | #3 |
9
Rep 79
Thanks... They were only about $90 a wheel, which I thought was pretty damned cheap. I believe they're +43 offset.
I didnt know my factory wheels had spacers - the car came with the performance package and style 195 wheels. |
11-04-2011, 01:10 PM | #4 |
207
Rep 3,175
They don't; what I meant was you could re-use the spacers that you would buy for your winter set-up with your OEM wheels for a slightly more agressive stance.
11-04-2011, 02:16 PM | #6 | |
207
Rep 3,175
The best way to be sure how mm's you can add without causing problems is to measuure like they do here... http://www.turnermotorsport.com/t-wheel-spacers.aspx |
11-05-2011, 07:39 PM | #7 |
Rep 108
I have spacer on mine with same factory wheel you have and i have 15mm up front and 18mm in the rear and it fit flush if you want ill get some picture for you.
11-05-2011, 08:16 PM | #8 |
9
Rep 79
These arent the factory wheels - my OEM wheels are the 195 style wheels (18x8 front, 18x8.5 rear) that came with the performance package.
But I would like to see what your 17" wheels look like with the spacers. If you could take some pictures and post them up, I'd appreciate it. |
11-24-2011, 06:02 PM | #11 |
Rep 108
I got them from pyspeed they usually have a discount code. They are the rs technik and they comes with bolts and everything so dont have to worry about getting the wrong bolt or anything. Sometime they have the same brand on ebay for like 20 bucks cheaper then there website. I also see people do 12mm front and 15mm rear. hope that help sorry for getting back to you so late was away from a computer for a long time.
