New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > E89 Z4 Classifieds > Commercial Z4 Classifieds
      11-03-2011, 02:13 PM   #1
ModBargains IV
ModBargains IV's Avatar
Drives: e92 335i, 135i, E46 M3, 540i
Location: 1721 E. Lambert Rd. Unit C, La Habra, CA 90631
**********s.com | COBB for the Z4 35i/is !? | In stock & ready to ship!
Hey ZPOSTERS!
Just got word from COBB that the beta testings on the Z4 35i/is are complete and COBB is scheduled to officially release the software after the SEMA show! So get your COBB APs today!
WE WILL MATCH/BEAT ALL PRICES INCLUDING GROUP BUYS!!!
In-stock for immediate shipping
Questions? Need Help? Give me a call here at ************** x 8003 or ask for Frank!
The Cobb Tuning AccessPORT ECU Flash simply replaces conservative factory settings with more aggressive calibrations that result in impressive gains in torque and horsepower while still maintaining a high degree of safety for your N54 engine. The tuning is extremely flexible and allows you to choose on the fly one of the performance maps that are loaded onto the AccessPORT. If you are looking to extract the most out of your N54 the AccessPORT even allows for custom mapping. Typical performance gains from the Cobb AccessPORT are increases of 30% peak horsepower and an amazing 38% increase in peak torque. This tune is an ECU flash, not a piggy-back tuner, there will be no added devices to your vehicle's ECU.
[IMG]http://www.**********s.com/zoom_img/_1296044825.jpg[/IMG]
[IMG]http://www.**********s.com/zoom_img/_1296046827.jpg[/IMG]
[IMG]http://www.**********s.com/zoom_img/_1296044848.jpg[/IMG]
Features & Advantages:
  • * Up horsepower by 30% (approximately 100 horsepower)
  • * Increase torque by 38% (approximately 120 Ft./lbs)
  • * ECU flash, not a piggy-back tune
  • * Installs in minutes using easy to use AcessPORT interface
  • * Installs via OBDII connector, no tools required
  • * Grows and changes as your modifications do
  • * Uninstalls in minutes to return your ECU to stock configuration
  • * Conveniently log data values for up to 10 hours without a bulky laptop
  • * Integrated performance tools to record 0-60 times, 1/4 ET & trap speed
  • * Intuitive DTC code reading to help diagnose issues
  • * Easily clear ECU codes
  • * 30 day satisfaction guarantee
  • * Downloadable free performance maps as released
Applications:
  • 2009-2010 BMW Z4 35i/is E89 (N54)
  • 2008-2010 BMW 135i
  • 2007-2010 BMW 335i/xi/xDrive
  • 2011 BMW 335is
  • 2008-2010 BMW 535i/xi/xDrive
Typical Performance Gains:
Stage 1: +30% Peak HP & +38% Peak TQ
(see modification requirements here)
[IMG]http://www.**********s.com/images/Products/Cobb%20AccessPORT/Cobb-AccessPORT-135i-335i-535i-Dyno.jpg[/IMG]
Note: Base line results yielded with stock ECU / 91 Octane / 93 Octane
Stage 2: 09/22 BETA RELEASED:
(see Stage 2 BETA details here)
Stage2 and Stage2+FMIC maps take advantage of additional modifications that improve engine breathing efficiency, resulting in large gains in torque and horsepower over Stage1 equipped cars and over 50% gains in peak torque and horsepower over stock!
Stage 2 Hardware Requirements:
Stage2 – Intended for vehicles equipped for the following hardware:
  • * Requires upgraded high-flow downpipes (catted or catless are acceptable)
  • * Upgraded cat-back exhaust system recommended, but not required
  • * Upgraded intake system (DCI, panel filter or otherwise) recommended, but not required
Stage2+FMIC – Intended for vehicles equipped for the following hardware:
  • * Requires upgraded front-mount intercooler (FMIC)
  • * Requires upgraded downpipes (catted or catless are acceptable)
  • * Requires Upgraded intake system (DCI, panel filter or otherwise)
Installation:
Installation for the Cobb AccessPORT for the N54 is a breeze, and does not require any tools or computers. Below is a simple installation tutorial.
      11-03-2011, 03:43 PM   #2
KCSchoey
Drives: 2011 Z435i
What is the difference between the 2011 Z435i w/DCT and the 2011 Z435is that allows this to work with the 35is and not the 35i?
I've got a Z435i w/DCT and definitely be interested in this product, but based on the Application list above this won't work on my vehicle.
Thanks.
      11-03-2011, 05:53 PM   #3
ModBargains IV
Thanks.
I believe the 2011 Z4 35is still uses the N54 engine just like the 2011 BMW 335is coupe and the 2011 Z4 35i uses the N55 engine.
COBB won't be developing the a software for the N55 until the Pro Tune is finished for the N54 . At least that's what I've heard...
-Frank
      11-04-2011, 08:51 AM   #4
KCSchoey
Drives: 2011 Z435i
pretty sure the 2011 Z4 35i has the N54 as well. That's why I thought it strange. I may just end up ordering one anyway. I don't see why it wouldn't work on the 2011 if it works on the 2009 and 2010. They should all have the N54.
      11-04-2011, 10:55 AM   #5
ModBargains IV
If the 2011 Z4 has an N54, it will work, but I'm pretty positive the 2011 BMW Z4 35i has an N55, while a 2011 BMW Z4 35is uses the N54.
      11-04-2011, 12:38 PM   #6
Malfunction
Drives: 2015 Porsche GTS
In Canada at least the 2011 35i is the N55, while the 35is is the N54. In 2009 / 2010 the 35i had the N54 engine.
      11-04-2011, 03:28 PM   #7
KCSchoey
Drives: 2011 Z435i
Yeah, I think the US version is still the N54 for 2011 or at least this thread seems to indicate it is.
http://e89.zpost.com/forums/showthre...05#post9659245
      11-16-2011, 11:07 AM   #8
ModBargains IV
Hey Zpost,
Good news! Just confirmed with COBB this morning that the Z4 applications are good to go. Only the Stage 1 available right now, but in the next few weeks they should be releasing other stages.
PM me or call me at 714 582 3330 ext 8003 for a special ZPOST discount on the COBB APs personally from me.
-Frank
      02-03-2012, 01:57 PM   #9
ModBargains IV
Keep the PMS coming!
zpost
