I need to replace front bumper for 3 series. HELP!!!!
11-02-2011, 05:43 PM | #1 |
Rep 2
Hi, I was hit in my front bumper recently and have to pay for a replacement. I know bmw replacements are very expensive, but the only thing damage in the accident was the front bumper (no parking sensors) and one skirt grill. I found one front bumper painted black (color of my car) on Craiglist which is flawless. Is this a job I could have done relatively inexpensively, or could I do this myself? If so, how? I need to fix the foglight(working) in place as well as adding a new left skirt grill, but besides the bumper cover, everything is fine. Thanks in Advance for any responses!
Attached Images |
11-02-2011, 06:31 PM | #2 | |
14
Rep 170
Just tell them you need a left side finisher rid for your car. |
11-02-2011, 06:37 PM | #3 |
153
Rep 3,730
#1 - Buy the new bumper, make sure it's the correct one (e90 non LCI)
#2 - Remove stock bumper (jack, 8mm socket, socket wrench, socket wrench extension, and torx bits) There are 4 torx screws on the top, about x8 8mm under the bumper, x2 or x3 8mm in each wheel well, and x2 8mm under each wheel well (these are the toughest to remove so use the extension) #3 Pull bumper off and unscrew (90deg turn) the fog light bulbs from the housing #4 Reverse steps for the install (might need a new fog light bulb if yours is broke) #5 Lose the chrome rims Takes only 15 min to remove the bumper.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
11-02-2011, 07:57 PM | #4 | |
138
Rep 2,731
while it is off i would make sure the actual bumper, (big metal thing) is straight and that it hasn't compressed on the side that got hit. just measure left and right side clearance and see one side sticks out further. |
11-02-2011, 08:02 PM | #7 |
138
Rep 2,731
11-02-2011, 10:03 PM | #8 |
Beamer Mantic
82
Rep 1,191
Upgrade your stock bumper with this OEM BMW M Aerodynamic Front Bumper Kit. Kit includes front bumper, left, right, and center grills, fog lamps, fog lamp supports, fog lamp plug sockets, adapter, left and right deflector lips, headlight washer nozzle covers (if applicable), and left and right wheel housing covers. 335i's also include required support and airduct.
http://www.trademotion.com/partlocat...catalogid=4462
2006 325i
2006 M5 2008 X5 4.8i 2014 X5 50i M-Pkg |
Tags |
3 series, front bumper, replacement, skirts |
