BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Car won't program after radio is changed.
      05-08-2007, 04:55 PM   #1
///Matt
United States Marine
///Matt's Avatar
Drives: 2007 Dodge Ram 1500
2006 330i  [0.00]
So, I had an E90, the most base model 325i, in here the other day... it had a an aftermarket flip out dvd player instead of the radio...
I replaced a fautly airbag control module, and then sent the car to programming to activate the module.... unfortunately, Progman has this "quirk"... if a module is failed, and can't be programmed, it won't even start the rest of the car. In this case, the radio was missing, so the car wouldn't program.
So now this fella has to go to his radio shop and have his factory radio reinstalled, and the radio harness repaired (they HACKED it up), before he can have working airbags.
Now keep in mind, folks... this was the MOST BASE model 325i. It didn't even have any other MOST modules except the radio.... but the car still wouldn't program without it being accounted for.
If this was, say a 335 with the L7... and you're replaced the radio, amp, etc... you'd have a lot of work and $$ ahead to get it to program correctly.
      05-08-2007, 06:57 PM   #2
fullrev
2011 E92 M3
fullrev's Avatar
Drives: 2011 E92 M3
i would submit a puma case and ask for modified vehicle order to trick the sss to think the car doesnt have a radio
2011 E92 M3 6MT
Gone - 2007 E90 335i
      05-08-2007, 07:14 PM   #3
///Matt
///Matt's Avatar
2006 330i  [0.00]
I don't beleive you can get a VO that says codes "not equipped with radio". The VO just tells the car which level of equipment it DOES have. If you were to say, delete the line which says which radio it has, I'm betting it would give you an error message and still not program the car.
      05-08-2007, 07:47 PM   #4
JSpira
Freude am Fahren
JSpira's Avatar
Austria
336
Drives: Fünfer, Dreier, +
Please let us know how much this, uh, idiot has to spend to get is car back into working order.
I´ve been pointing out for several years that you may not be able to program the car - now you have provided further evidence. :rocks:
Freude am Fahren.
Jonathan
E90 2006 330xi
E90 2006 325i
E39 2003 530i Sport*
E46 2000 328Ci*
E36 1996 328iS*
E36 1992 325i*
E30 1991 318is
E21 1982 320iS*
E21 1979 320 (6-Zyl)*
*retired
Nominated: Most Contributing Member
      05-08-2007, 09:41 PM   #5
///Matt
///Matt's Avatar
2006 330i  [0.00]
I doubt I'll know how much he ends up spending, since I probably won't see the car again.
But look at it like this:
Labor to have his original radio reinstalled, if he's still got it, is probably no higher than $200, if that....
but if he left his radio with them, or threw it out, that's another $1000 or so. ouch.
