Adjustable suspension (dampers) for best 60ft with no wheel hop at the drag strip ?
10-27-2011, 09:06 AM | #1 |
151
Rep 1,809
Hi,
I have in plan to replace my M-Sport suspension with an adjustable suspension. Does anyone think that a good set of adjustable dampers (eg. Ohlins Road & Track which I can get for a reasonable price, or Bilstein PSS10 or even KW V3) can help with eliminating wheel hop and increasing traction off the line ? I was thinking at the following settings: - front - set the rebound rate as soft as possible - rear -set the rebound rate as hard as possible But if the rebound rate is soft in the rear, doesn't this promote wheel hop ? If the suspension has adjustable compression (like KW V3) this could also play a role, but I am not sure if this matters given the springs which control compression ? Also, what springs would be better for drag racing ? Softer or stiffer springs ? |
10-27-2011, 09:25 AM | #2 |
48
Rep 932
Generally, the idea is to have a higher spring rate up front, and a lower in the rear. This allows weight transfer to the rear of the car allowing the to "squat" and go reducing wheel spin. I'm not a pro with rebound settings, so I can't help you there.
10-27-2011, 09:56 AM | #3 |
39
Rep 1,154
The more you car squats in between shifts the slower you are going to be. You want the rear to be stiff, that's why some guys will use spring blocks, this way the rear squats as little as possible.
10-27-2011, 10:00 AM | #4 |
48
Rep 932
A stiff rear is just going to cause wheel spin. I've been through it with my 350Z, I couldn't make the car hook up at all with 295/40/18 semi slicks on the rear.
10-27-2011, 05:01 PM | #5 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
A long time ago when I was racing a strip only car I was using 90/10 front & 50/50 rear to allow for good weight transfer but still control wheel hop.
BTW 90/10 are a bad plan for a street car.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
10-27-2011, 06:43 PM | #7 |
168
Rep 842
I had a 2005 E46 M3 with Bilstein PSS9's and no matter how I adjusted it, I still had some wheel hop... it's the curse of the independent rear suspension...
I would suggest having more weight in the rear (half tank of gas, leave seats in) and get some good tires with fat sidewalls, ie 17's
10-27-2011, 08:52 PM | #8 |
30
Rep 468
You want softer rear springs. Stiffer front springs won't matter too much. To go with the softer rear springs you want a damper that has very little compression and a shit load of rebound. The low compression damping will allow the rear to compress easily, but the high rebound will keep the springs from extending keeping the rear squatted and load transferred to the rear. You will also want very little camber in the rear as the more it squats the more negative camber is gained.
01-24-2016, 05:03 PM | #10 |
Real Car Enthusiast
288
Rep 2,082
Tires and pressure are also a cause of wheel hop. Shiv had a set of $4500 coilovers on that car with lightweight Kosei K1s and Hoosier bias plies. All recipes for good traction without wheel hop
01-26-2016, 10:29 AM | #12 |
4ut0strd4
47
Rep 223
Whatever suspension mods you may end up doing make sure you lock the diff down with some sort of brace. Even if I went polly bushings and an lsd I'd still do it because any little bit that diff moves when loaded will transfer power to the passenger rear wheel unevenly assuming you are going forward not backwards lol.
On a side note being stock suspension just springs and shocks all of my wheel spin and hop is basically gone after installing the diff brace. Hooks solid with proper tires and I'm very satisfied. Running fbo plus meth and with a little e85 my car is making around 500hp and 550tq at the crank mustang dyno proven after taking drivetrain loss into consideration (about 15% according to the operator) which overall makes me happy. Just a very bumpy ride... |
01-26-2016, 01:36 PM | #13 | |
75
Rep 168
01-26-2016, 01:38 PM | #14 | |
75
Rep 168
Any idea on what bushings are affecting a launch? I know the rear subframe is; which I've addressed with inserts. Not too familiar with how suspension geometry works :/ |
01-26-2016, 05:00 PM | #15 | |
379
Rep 909
I'd look towards any bushings that are part of the wheel to chassis connection, like suspension arm bushings. |
01-26-2016, 05:24 PM | #16 | |
161
Rep 3,736
01-26-2016, 09:02 PM | #17 |
75
Rep 168
