Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Help. Installed Cobb AP on my 2011 335is...now I cannot uninstall or change maps
      10-25-2011, 08:05 AM   #1
vinnymac
158
Drives: 2024 X5 50e
I have a 2011 335is and I installed my AP tonight. I updated to the current firmware with 335is support and flashed the Sport map on my car. The install appeared to go smoothly. The car definitely has more power and is very driveable.
However, I now have a problem when I try to change maps or uninstall the AP. I get the "Accessport not installed on this vehicle" error when it checks the ECU.
I checked the contents of the AP with the manager and it looks like it saved my ECU configuration but it will not recognize my car now.
v1.6.5.0.2839 firmware
Map Stg1 Sport IKBOS IS v301
Error Message: Accessport not installed on this vehicle" 0 BMW_MSD81_0044CCOIKBOS_IS
How do I fix this?
Update: 11/14/11 - I received my updated AccessPORT with alpha firmware and instructions on uninstalling it from my car and subsequent steps on how to reinstall on my car. I followed the steps and it appears everything is working properly.
      10-25-2011, 09:07 AM   #2
xclone
Putting more gas in the car...
Drives: 2008 535i
How do I fix this?
Did you unplug the device or turn the car off when you were loading maps? Sounds like it did not take and the map is really not loaded onto your car. Does it give you the option to re-install? How about recover (which is what it will do automatically if it fails to install properly).
Personally, I would call Cobb directly. Any other advise may cause issues.
2008 BMW 535iA | Cobb Stg2+ | Injen Intake | AR Catted DP's | CP-E FMIC | Turbosmart DV's | ER Charge Pipe
      10-25-2011, 09:12 AM   #3
vinnymac
158
Drives: 2024 X5 50e
The install went smoothly and the car is running the Stg1 Sport map. There is a noticable power gain. I'm going to call Cobb today to get their feedback.
      10-25-2011, 10:19 AM   #4
Beemw335
62
Drives: 335i
Try reloading the map and see what it does.
Keep trying to go back to stock. And call up cobb.
      10-25-2011, 10:22 AM   #5
vinnymac
158
Drives: 2024 X5 50e
It won't let me do anything at this point. Trying to switch maps or uninstalling (returning to stock) results in the same "Accessport not installed on this vehicle" error.
I talked to Cobb this morning and they want me to revert to the last non-beta firmware and try to connect to ECU. They didn't sound very optomistic but wanted me to try it. I had to run the beta-firmware to get the 335is maps to begin with.
      10-25-2011, 10:54 AM   #6
pHo_e92
pHo_e92's Avatar
32
Drives: SGM e92
2008 BMW 335i  [7.26]
2000 BMW 323i  [6.00]
1997 Honda Civic HB  [10.00]
2007 BMW X5 4.8  [10.00]
did you update your AP after you installed it on your car? Also make sure that your FOB is in and your ignition is in the ON position, then plug your AP in and see if you can do change maps then.
08 335i | Space Gray | Burl Walnut Wood Trim | Sport pkg | Premium Pkg | LOGIC7 | Navi | Comfort Access
| COBB | Injen DCI | Active Autowerke | Sonic Tuning | E92 Lighting | ER | HKS | BMS | Ground Control | Vortex Tuning |
      10-25-2011, 01:31 PM   #7
vinnymac
158
Drives: 2024 X5 50e
No I did not update my AP after the installation. My FOB was in the ignition the entire time.
I've escalated the issue to COBB and they are working on a resolution. They said my issue was a bit odd but not the first time there has been issues certain models of BMW. COBB customer service has been great.
      10-25-2011, 01:43 PM   #8
BQTuning
Drives: 2012 Z4 sDrive35i M Sport 6MT
Suscribed.....I need to keep track of this cause I surely dont want this happening when and if I do flash Cobb on my pet
      10-25-2011, 02:30 PM   #9
COBB Tuning
COBB Tuning's Avatar
233
Drives: 335i
This is an issue we are aware of, and we are working hard to find a solution! I'll be sure to update this thread and our main AccessPORT thread once we have found a work around and a proper fix.
Ian
      10-25-2011, 09:21 PM   #10
asifjahmed
Drives: 2011 335is
I also have a 335is and just ordered an AP. Should I be waiting for the fix before attempting my install?
Thanks.
      10-26-2011, 08:47 AM   #11
pHo_e92
pHo_e92's Avatar
32
Drives: SGM e92
Ok sounds like Cobb is taking care of you. Hope it gets resolve quickly
      10-26-2011, 03:09 PM   #12
Alessandro
Alessandro's Avatar
Serbia
111
Drives: Audi RS5
2011 335is  [9.50]
Ian
i am kind of dissapointed; Cobb knows about it but still no info that potential buyers should be aware, i hope this is not the standard business practice they use.
Again nothing against Cobb great product but potential customers should know beforehand about that issue on the 335is especially if its known to them.
19 Audi RS5
15 Audi S5 GIAC Stage 2 white
11 E92 335is DCT FBO 441 whp silver
08 E92 335i FBO 6MT 427 whp space grey
05 E46 M3 red
      10-26-2011, 03:19 PM   #13
vinnymac
158
Drives: 2024 X5 50e
Ian
Ian - thanks for posting in this thread. I'm eagerly waiting to hear back from your team with a fix for this issue. Right now my car is running but my Accessport is rendered inoperable as it will not accept the beta firmware it was running and it will not communicate with my ECU.
Thanks for the great customer support!
Vince
      10-26-2011, 03:36 PM   #14
cn555ic
cn555ic's Avatar
Drives: 335i
Wow thats scary! Hope you get some solution soon.
      10-26-2011, 03:54 PM   #15
M3WC
3645
Drives: BMW
Thanks.
My buddy has been running the Cobb on his 335is for months. Zero problems, runs great.
      10-26-2011, 05:59 PM   #16
COBB Tuning
233
Drives: 335i
Thanks.
If your are updating to the Beta Firmware before installation, you shouldn't have any issues.
Ian
      10-26-2011, 06:58 PM   #17
GoodtoGo
GoodtoGo's Avatar
69
Drives: M3
Ian
You suggested yesterday that people not update their firmware.
We are currently aware of a problem some users are having when updating their AccessPORT to Beta firmware. We are working hard to find a fix and we will update you with our progress!
At this time, I would recommend not updating your AccessPORT. Currently, there are no new releases that would affect the performance or safety of your vehicle of your vehicle, so beta updates are not needed. As always, if you have any questions, please send us a PM, email (tech@cobbtuning.com), or call (866-922-3059).
Ian
      10-27-2011, 02:15 PM   #18
COBB Tuning
233
Drives: 335i
Sorry for the confusion! Updating a current AccessPORT that is installed on a vehicle could potentially cause this issue. If the AP is uninstalled, there shouldn't be any kind of issue.
Ian
      10-28-2011, 09:40 AM   #19
vinnymac
158
Drives: 2024 X5 50e
I received an email from Cobb indicating there was a new beta firmware version available for me to try. I updated my AP without issues and now at the AP can communicate with my ECU. I was able to get into the Monitor menu and I was able to get into the Troubleshoot menu and reset the ECU. However, I am still getting the "Accessport not installed on this vehicle error".
I sent my feedback to Cobb and I'm waiting on the next step.
Fingers crossed they find a solution so I can change maps and uninstall before my first dealer service visit.
      11-07-2011, 11:23 AM   #20
vinnymac
158
Drives: 2024 X5 50e
Update: 11/7/11
Cobb Tuning has been great working on a solution to this problem I'm having with the AP. I tried to use alpha firmware last week but it would not install on my AP so I had to ship it back to Cobb.
Their RMA system sent me an email indicating my AP was received so my fingers are crossed a solution is in my hands soon.
      11-14-2011, 03:35 PM   #21
vinnymac
158
Drives: 2024 X5 50e
Update: 11/14/11
Cobb Tuning's cusomter service and RMA process was handled exceptionally well and I am pleased with the resolution. I'm glad everything is back in order and now I can focus on enjoying my new car for a few more weeks before the winter weather settles in.
      11-14-2011, 05:00 PM   #22
BQTuning
Update: 11/14/11
I have been following this thread from day one and I have been waiting for your update. Now, do us, me etc a favor and get some numbers posted .
Thanks
