Looking for some track rims
10-24-2011, 10:05 AM | #1 |
30
Rep 809
So I have recently started to track my car. I'm looking for a set of track wheels so that I don't eat up my road tires/rims. I want to run 255/40 on a 17x9 rim, square setup. After some research, I found out that not all 17s clear the front brake on an e92 335i. Any suggestions? I want a lightweight 17x9 track rim that won't break the budget. I have been looking at Enkei PF01/RPF1. Also what sort of offset to I get with a square setup so that it doesn't look funky? Thanks in advance.
10-24-2011, 11:04 AM | #2 |
81
Rep 1,510
Relevant threads in the track forum:
http://www.e90post.com/forums/showthread.php?t=600080 http://www.e90post.com/forums/showthread.php?t=581312 My advice: Arc8s or Koseis |
10-24-2011, 11:39 AM | #3 | |
30
Rep 809
10-24-2011, 12:09 PM | #5 | |
2006 330i, TSM, Black, manual, sport
882
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
They only come in et40, so I'm running a 5mm spacer front and rear. Not rubbing issues using 235/40 BFG R1.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
10-24-2011, 12:38 PM | #6 |
30
Rep 809
Thanks for the info. Did you try running RPF1s in 17? I want to get 17s because tires are cheaper. Planning on running R comps that don't last long.
10-24-2011, 01:18 PM | #7 |
172
Rep 1,910
Check these out if you want some really good track wheels.
http://www.e90post.com/forums/showthread.php?t=579698 http://www.e90post.com/forums/showthread.php?t=595330
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
10-24-2011, 03:04 PM | #8 | |
30
Rep 809
10-24-2011, 04:43 PM | #9 | |
81
Rep 1,510
The OP on the first link I included is about to try 255/40 square on his coupe, and there are a couple of other examples of 255s fitting ok (under specific circumstances). |
10-24-2011, 09:28 PM | #10 | |
30
Rep 809
10-24-2011, 11:18 PM | #12 |
30
Rep 809
10-25-2011, 11:31 AM | #14 | |
882
Rep 3,699
As a side note for R-comps. I work on the Bimmerworks race team and we run 18" OZ wheels. The tires are BFGoodrich R1, 265/35 square. Yes, they do rub slightly in the front, but there is no wear on the tire due to the rubbing. At the 12 hour race in April, we ran for 7 hours straight on the same set of R1's and they still weren't worn out.
10-25-2011, 12:26 PM | #15 | |
81
Rep 1,510
http://www.e90post.com/forums/showthread.php?t=600080 AFAIK, there's no 17x9 K1, only 17x8.5 |
10-25-2011, 12:28 PM | #16 |
81
Rep 1,510
