      10-24-2011, 06:41 AM   #1
E82M
15
Drives: 2011 AW E82 M
Moton Clubsport vs. KW Clubsport ?
hey guys,
I'm trying to decide on coil overs for my 1 //M.
The car will be pretty much weekend / trackday car.
Previously, I had KW V3 on my 370z and I was quite satisfied with the KW compared to other popular brands for 370z such as TEIN Monoflex and such.
Okay, let me get to the question.
I'm trying to pick one. Either Moton or KW.
I know Moton is more track focused suspension.
My concern is the ride comfort (little concern), is it unbearable to drive on the streets?
Help me to decide.
      10-24-2011, 08:49 AM   #2
M3 Adjuster
Albania
7905
Drives: 1M, X1 M Sport, E46 325ic
to me this is a no brainer... Go with Moton.
      10-24-2011, 08:54 AM   #3
Oaktree
Oaktree's Avatar
Drives: 2012 X5 - 2010 M3 - 1999 M3
Why not AST? They should be in the consideration set. Moton over KW though.
      10-24-2011, 09:46 AM   #4
Advevo
578
Drives: M2 Competition, E30 M3 DTM
Just wait a few weeks.
JRZ has 1M coupe suspension on it s way.
I am getting a JRZ suspension when they are ready to go on the car.
This suspension is also made as a compromise between road and track days. The bump and rebound can be adjusted also.
When they arrive i make pictures of them.
I be on the Nurburgring on 15 november to see how they go overthere i make a movie then also. Try to find a good setup with the bump and rebound.
      11-03-2011, 01:27 AM   #5
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Two different categories of products, and very different price range.
Moton Clubsport are racing dampers. They are sold as dampers only, and you (or your vendor) add camber plates, mounts, springs, etc. to make it work. Moton Clubsport are monotube with remote reservoirs and requires N2 pressurization.
KW Clubsport is a hybrid street/track set up. A mix between the V3 and the Competition line. They are sold as a plug and play kit. No remote reservoirs.
In terms of ride, it all depends on your set up, e.g. springs, damper settings, mounts etc. Either can be made to be comfortable on the streets.
      11-03-2011, 06:16 AM   #6
LateralG'z
LateralG'z's Avatar
Drives: Hopefully a 1M
Good to know and thanks for the clarification
      11-03-2011, 06:41 AM   #7
Pete_vB
Pete_vB's Avatar
Drives: '69 GT3, GT4, 1M, 912
Does anyone know what the stock/ oem dampers are?
We should probably throw Ohlins in the mix too- maybe the best design out there with their race products.
I would like to learn more about the offerings specific to the 1M/ M3, especially in the dual use street/ track range. I've had JRZ 1x, JRZ 2x and Moton 3x on previous Porsches, but always full-race, never club-sport. My impressions are that Moton and JRZ are very similar in internal design, but that Moton is slightly higher quality. I tend to feel that AST is in the same range depending on model, KW is one rung down and the Ohlins one rung above everything else mentioned.
Has anyone done or seen a good shock-dyno of a 1M stock?
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
      11-03-2011, 06:56 AM   #8
eeghie
Kind of a big deal
300
Drives: an 1M not often enough
I'll post the shock specification graphs as soon as I have some time to finish my ED post (in a comparative graph with the M3 ZCP EDC shocks), they are made by BMW's longtime shock supplier ZF/ Sachs/ Boge. The 1M front shocks are equal to E9X M3 ZCP shocks, IIRC the rear shocks are unique to the 1M
      11-03-2011, 07:16 AM   #9
Pete_vB
Pete_vB's Avatar
Excellent. Do you also know the 1M spring rates? That'd give a very nice place to start.
      11-03-2011, 08:23 AM   #10
robertm
450
Drives: 2020 M2 Comp
That sounds about right to me too. Uncoincidentally that correlates nicely with their cost of entry too
Suspensions are lot like any other mechanized product. The more you spend the better performing and happier you will be. All of the brands mentioned above make a quality product. Spending more will get you a better lap time though and better overall ride in general (comparing apples to apples, not street vs track focused units).
I can still remember when the high end shocks like JRZs first hit the prepared club racing scene. The guys running them were suddenly seconds up on the rest of the field.
      11-03-2011, 11:55 AM   #11
eeghie
Kind of a big deal
300
Not looking to lower the car nor change its weight, thus have not looked into the spring (-rates). OEM spring rates are quite tough to get a hold off as BMW uses a configuration dependent selection per corner (fi per corner stock M3 can use any out of 5 different spring rates depending on weigth and location of the selected options).
      11-03-2011, 12:48 PM   #12
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
The founder of Moton, Jerome, used to be part of JRZ. That's why their constructions are similar. Rebound is controlled on the shock via opening/closing small orifices and compression is controlled on the remove reservoir.
Last year, Moton upgraded its Clubsport line so now it is basically its Motorsports 2-way. I had this set up on my M3, and the beauty of Moton is its wide range of damping adjustment which really suits cars at the club sport level because you can significantly up/down rate your springs without revalving the shocks. Moreover, the dampers can be set to be very soft which gives a good ride. In terms of noise my dampers squealed a little due to N2 pressurization and the seals.
Ohlins (TTX line) are a completely different animal. They are a twin tube design with a solid piston. Damping is completely controlled by external valves mounted on the body of the dampers. Some of them feature through-rod, meaning the shaft goes through the entire shock, so no damping fluid is displaced inside the damper during compression and rebound. This means that the lift force due to pressurization is always the same and you can precisesly control the damping curves. These dampers are used on the ALMS M3s.
I've tried many suspension kits/springs on my 335/M3 (H&R coilover, springs, Dinan springs, Moton Street Sport, Moton Clubsport, KW Clubsport and KW Competition), and besides dampers, what is just as important is how your suspension is spec'd and set up (i.e. spring rates, damping settings, etc). You can have the best dampers in the world, but without a proper set up they will do you no good.
      11-03-2011, 12:57 PM   #13
MDORPHN
291
Drives: AW 1M
Great post.
How would you compare AST? Do they operate similarly with orifices instead of shim stacks?
Also, what, if any, changes to do you expect at Moton now that it has been acquired by AST? FWIW, I understand that a couple of employees recently left Moton's US operations to start their own company.
Thanks.
Neil
      11-03-2011, 12:58 PM   #14
Die ///M Rakete
Die ///M Rakete's Avatar
Drives: 2016 F80 ZCP 6MT
rldzhao....buddy your M3 looks WICKED!!!
      11-03-2011, 01:08 PM   #15
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Originally Posted by MDORPHN View Post
Great post.
Thanks.
Neil
I have limited experience with AST, and therefore cannot comment. But I have a few friends who have AST and they like it very much.
AST's first priority was to get Moton's racing dampers back in production and resume their services. As far as the future I suppose Moton will continue to focus on high-end racing dampers.
      11-03-2011, 01:16 PM   #16
MDORPHN
291
Drives: AW 1M
Thanks.
I ran AST 4200s on my previous car (a much-modified '99 M Coupe) and liked them. Just not sure how their "internals" compared to the Motons.
Neil
      11-03-2011, 01:40 PM   #17
eeghie
Kind of a big deal
300
These are shock specs of the stock 1M suspension (not Dyno), Would be interested in graphs of the threat title shocks, can someone post?
      11-03-2011, 02:56 PM   #18
Pete_vB
Pete_vB's Avatar
Holy compression damping, Batman!
Where did these come from? I must say I'm pretty surprised- I'm not familiar with BMW's shock tuning, but it almost looks to me like rebound and compression are reversed!
      11-03-2011, 06:55 PM   #19
eeghie
Kind of a big deal
300
... I'm pretty surprised- I'm not familiar with BMW's shock tuning ...
+1
What struck me is that although the weight of the car is in perfect balance, the rear shocks are quite a bit stiffer R/F = ~3800[Ns/m]/~2800[Ns/m] = ~136%. This ratio is quite larger than fi the M3 shocks where front and rear shock compliance is largely equal (referring to E9X M3 ZCP shocks).
In service to OP's selection of upgraded shocks, I hope the more experienced shock-ers among us can also help all of us understand the 1M OEM setup better.
I would assume significant reasons could be to battle understeer (car will roll & pitch towards the outer corner front wheel) and to prevent excessive wheel torque jitter ???
      11-03-2011, 07:06 PM   #20
Pete_vB
Pete_vB's Avatar
+1
What struck me is that although the weight of the car is in perfect balance, the rear shocks are quite a bit stiffer R/F = 136%. This ratio is quite larger than fi the M3 shocks where front and rear shock compliance is largely equal (referring to E9X M3 ZCP shocks).
So first, I am fairly convinced that rebound and compression are mis-labeled on those graphs. I ran some simulation numbers and came out with rebound higher than compression (which is the norm), so I wouldn't want to read to much into these before that can be double checked.
Second, I'm not surprised the rear is overall stiffer than the front. Assuming the 1M's motion ratios are identical to the M3s (purely an assumption on my part based on what I've read about the M3 and 1M sharing parts) then the rear motion ratio is something like .56 vs a front of .96. This means the rear shocks would need to be much stiffer at the shock itself to have identical values at the wheel. Quick rough simulation suggested rear shocks almost 3x stiffer than the fronts would be about right- these are less than 2x, suggesting they may be softening up the rear (likely both springs and shocks?) to help put power down. Seems to make sense.
Could you post the M3 values you have as well? Any way to double check bounce if and rebound are labeled right?
      11-03-2011, 07:32 PM   #21
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
Do you have the raw data? Graphs are a little hard to read
      11-03-2011, 07:49 PM   #22
MDORPHN
291
Drives: AW 1M
A well-known suspension tuner who tested the stock springs told me that the fronts are in the 220-240 range and the rears 540-550.
Neil
Search this Thread:
Advanced Search
