Dyno went bad? +video
10-23-2011, 06:20 PM | #1 |
36
Rep 332
Dear all,
I decided to dyno my car on a Mustang dynamo meter. My car is FBO + fully catless + meth 80-20 (pps system) + 7-19 "custom tuned" (check the trhed named "fun with ignition retard") So... here are the results: The car made 376 rwhp and 52.2 kgm rwtq (ignore the ft-lb, it's kgm). It's far from the 430-440 rwhp that some people get from a dynojet. This is a Mustang dyno so it is considered to be more strict than the dynojet and get power with the wheels on the car including their inertia. Here is the datalog: OK, before discussing the ignition advance which is terrible by the way, CAN dwb throttle is only 78%. Does it mean that the gas pedal was not hit on the floor? Or just a procede bug? I have terrible ignition drops. I just logged the car and it hits 15.5 degrees of ignition retard which is perfect. Methanol flow fluctuates between 11 and 16, not a solid 15 that I used to have. Is that an indication that the car was not WOT? The car was dynoed at a tuner's dyno. This tuner has maybe the most powerful custom reflashes from all the cars I have raced. Those cars make 410-420 with meth on the same dyno. After some discussion with the tuner he told me about the torque converter. If I understood it right, torque converter is a ROM inside the stock DME (an equation) that controls ignition, fuel trims and boost. If you introduce an amount of torque, then this equation changes the data coming out of the DME so the car makes less power. After a reflash, this ROM changes and handles power in a different way. Some cars make this power with just over 18 psi overboost and 15.5 psi constant. A car with this tune makes 30 whp more at 4800 rpm and 56 whp more at 6500 rpm. Tuners please chime in. Here is the video from the dyno: So, except the throttle and poor ignition, what might be wrong with my car or the dyno? |
10-23-2011, 06:27 PM | #4 |
Rep 232
correction factors can seriously take away or add insane amounts of horsepower and TQ...look into it...FYI dynos are used as a tuning tool...don't get wrapped up in numbers, it's how the car performs what matters most
Zu bestrafen und zu versklaven
10-23-2011, 06:31 PM | #5 |
My X5d tows my spec miata to the track.
74
Rep 1,254
Quit trying to figure something out that isnt there. Your timing is too high and continually being pulled. It's pretty impressive that you hit 376 on a mustang with that timing anyway. Pull a couple of degrees from 3k-5k and you'll have better top end results.
10-23-2011, 06:41 PM | #6 |
51
Rep 923
What size nozzle are you running for your meth injection? Also what was the ambient temperature during the test? Your IAT's seem a little high considering you're running meth unless it was really hot outside during the dyno. Your torque also seems low @ 377 lb/ft.
10-23-2011, 06:42 PM | #7 |
3441
Rep 79,211
78% is WOT
It looks your methanol needs some work and the boost is WAY too high. Lower your boost and fix your methanol. You may not be running enough but what is apparent is you have some flow issues. A little more information about all your modifications and details would help. Edit- Your intake temps are way too high too which is another factor showing methanol problems and too much boost. Last edited by Jeff@TopGearSolutions; 10-23-2011 at 06:57 PM.. |
10-23-2011, 07:20 PM | #8 |
442
Rep 18,331
Although its showing flow on the Procede reader from your flow sensor it is really odd that the temps climbed up to 107 degrees on meth...It had to be something wrong with the flow sensor and if its the crappy Lebonte unit, take a hammer to it and order a new one from either SNow or Aquamist to work with your PPS.
10-23-2011, 07:43 PM | #9 | |
Joint Chiefs of Staff
4920
Rep 115,999
Mike |
10-23-2011, 07:51 PM | #10 | |
1743
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
10-24-2011, 04:55 PM | #11 | |||||
36
Rep 332
For those that asked
Injen intake, Forge intercooler, Vishnu procede rev. 3 7-19, Riss racing catless downpipes, vk-motorwerks oil cooler, fully catless 3" custom exhaust, vishnu pps meth kit 20C ambient temperature (68F), 80-20 meth mixture, M7 nozzle Quote:
And here we are. I went for some logging tonight. Map 2, 19.2 psi and.... Meth started spraying and that was all. It raised to 2% and then the fail safe died. Maybe the pump died but fail safe seems to failed. Another Labonte failsafe fail here. When I replace it I will go for another dyno there. But nobody chimed in about the torque converter. I would like to comment what I initially posted. |
10-24-2011, 05:02 PM | #12 |
1743
Rep 17,960
Drives: A Lot
10-24-2011, 05:45 PM | #13 |
161
Rep 7,377
arent you even running map 4? Basically no failsafe?
10-24-2011, 07:45 PM | #14 |
51
Rep 923
52.2 kgm = 377.56332297 lb/ft of torque, so like I said, your torque seems low to me unless my conversion is off.
10-25-2011, 05:43 PM | #15 | |
36
Rep 332
Tonight I went out to my girlfriend. As I was going back home I had my map 1 engaged (15.5 psi) and I had left meth on. I felt a kick and hazard lights turned on. And yes meth was flowing. Changed to 4th gear, the car pulled crazy and then.... hazard lights turned off and car became slower. I didn't run out of meth, tank is at the middle. So, it looks like it is a failsafe problem No, I don't use map 4. Car feels slower rather than with map 2. |
10-25-2011, 05:44 PM | #16 |
36
Rep 332
10-26-2011, 08:26 AM | #17 | |
41
Rep 298
I am very curious if there is such a thing (torque converter) or it is another tuner trick to advertise his custom reflash. |
