Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Wheel fitment help! e92!
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      10-20-2011, 10:40 PM   #1
SouthfloridaE92
14
Drives: 2011 Black e92 335i 6MT
Wheel emergency, Plan on ordering my mm6 mesh wheels ( lm reps ) i have a e92 335i and was wondering what setup i should run on the sizes? I also have kw coils currently..
Should I throw on some 18's get a wider wheel and drop it for an aggressive stance?
or should I get 19's ?
I want an aggressive look with a wide but low profile tire..
I would go for 18's but 18s in the lm style look small, so 19's look perfect.
just would like to know your guys view on the situation..
So just post your recommended height with the FULL wheel and tire sizes please! and if i need spacers or new tpms! itd be a great help!
im relatively new to wheels/tires, im most likely going to be wrapping them in hankook v12's so please post the tire and wheel sizes, thank you!
      10-20-2011, 10:53 PM   #2
///M3NACE
///M3NACE's Avatar
172
Drives: E36 M3, E36 Vert , E90 N52
post widths and offset
      10-20-2011, 11:15 PM   #3
SouthfloridaE92
14
Yes please post recommended widths and offsets.. I really need some good advice here to learn a few things about em
      10-21-2011, 08:57 AM   #4
Pcemkr
Pro Hater
49
Drives: Low and slow
Run 9.5" et22 and 11.5" et37
      10-21-2011, 12:57 PM   #5
ModBargains.com
Drives: JB E92 335i
The MM6 Mesh wheel setup that is going to work best is the 19x8.5 ET35 with a 235/35/19 up front and the 19x9.5 ET33 with a 265/30/19 in the rear!
      10-21-2011, 10:50 PM   #6
pe90zzi
CuL SToRY BRaHH
pe90zzi's Avatar
63
Drives: a purple thing
Id go with 18's simply because you can go lower, ive always had 19's and realized that the only way to get low enough is on 18's. 9.5's arent aggressive enough if you want stance. Also 18's dont make the face look that small, i had that theory then i got my ccw's and honestly couldnt be happier, after you see it in person you realize that you dont need anything that big. If you want something comfortable (useful) and stanced out try 9's front 10's rear or even a 10.5 on a 285/35 looks awesome
well anyways in my opinion thats where its at
ooorrrr do 11.5's!
I own a car
      10-22-2011, 09:31 AM   #7
SouthfloridaE92
14
Thank you guys for your help! and ill be buying my wheels off you @ **********s!
      10-22-2011, 11:14 AM   #8
SouthfloridaE92
14
would 19x8.5 et 35 front and 19x9.5 et 33 on the rears fit well? i want it to be a nice agressive stance
      10-22-2011, 11:19 AM   #9
SouthfloridaE92
14
or should i go with the varrstoen 19x9.5 fronts and 19x10.5 rears with +22 all around?
      10-22-2011, 11:47 AM   #10
pe90zzi
CuL SToRY BRaHH
pe90zzi's Avatar
63
^this! NOT that^^^
I own a car
      10-24-2011, 07:52 PM   #11
SouthfloridaE92
14
Alright so would 255/30/19 toyo's stretch and fit good on the 19x9.5 rears? and on fronts 235/35/19 on a 19x8.5?
      10-24-2011, 09:33 PM   #12
ModBargains.com
Drives: JB E92 335i
The ideal and most common setup is the 19x8.5 ET35 with a 235/35/19 up front and the 19x9.5 ET33 with a 265/30/19 will fit the car perfectly. It will push the wheels out towards the fender as much as possible and will not require you to roll your fenders or run a stretched tire in anyway. Here are a few pictures of this exact setup on an E92 so that you can get check out the stance of this setup specifically.
[IMG]http://www.**********s.com/images/Products/885%20LM%20Wheel/DSC_0317.jpg[/IMG]
[IMG]http://www.**********s.com/images/Products/885%20LM%20Wheel/DSC_0319.jpg[/IMG]
[img]http://www.**********s.com/images/Products/885%20LM%20Wheel/DSC_0320.jpg[/img]
If you're looking for a more aggressive fitment, you can also run the 19x9.5 ET33 with a 235/35/19 up front and the 19x9.5 ET22 with a 265/30/19 in the rear. This setup will most definitely require you to roll your rear fenders. All in all, it comes down to the look your looking to get on the car and of course if you're willing to do the work to fit an aggressive setup.
      10-24-2011, 09:47 PM   #13
Pcemkr
Pro Hater
49
9.5" et33 is not flush and 255 on 9.5" is not real stretch
      10-24-2011, 10:13 PM   #14
pe90zzi
CuL SToRY BRaHH
pe90zzi's Avatar
63
go with the 10.5 rears!
I own a car
      10-24-2011, 10:18 PM   #15
335 oClock
MOE
335 oClock's Avatar
Drives: 2011 e92 335i 6MT
if it helps any I'm going 19x9.5 + 35 and 19x 9.5 +22, 2011' 335i e92
