Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Aggressive Fitment e90 Pre LCI
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      10-17-2011, 11:39 AM   #1
selshahE92
12
Drives: 2008 AW E90 M3
Hey guys I am going to be running the varrstoen lm reps on my e90 with a pretty low drop. I was wondering what size tire to run? I wanted to run 265/30/19 in the rear with a 235/35/19 in front. The sizes are 9.5 et22 front and 10.5 et 22 rear if I remember correctly. I know I will have to roll my fenders. But would this be ok? Do I need to run camber plates up front or am I good with just a coil over setup without it?
      10-17-2011, 01:10 PM   #2
Gavin@MMW
Gavin@MMW's Avatar
Drives: MMW Supercharged E90 328i
With a 235 up front you might want some FK bump stops, depending or ride height it will rub in the front wheel well - upper bumper mounting bracket -
Normally it is a 225/35 front and 245/35 rear for those wheels on this body.
a 265/30 will rub the rear bumper and fender mounting area, so that will need to be trimmed down also if you choose to go that way
      10-17-2011, 02:45 PM   #3
selshahE92
12
I don't mind the trimming in the rear but the front you say I need a bump stop. Ok I'll have to look into that. Anyone with pics with similar setups that can post pics?
      10-17-2011, 03:19 PM   #4
Gavin@MMW
Gavin@MMW's Avatar
this is my car, with the Varrstoen 2.2's in 19x10.5" et22 rear and 19x9.5et20 fronts:
265/30/19 rear and 235/35/19 front.
      10-17-2011, 09:25 PM   #5
selshahE92
12
I like your stance and fitment it's a
Spot on! So is what you said before what you did to make them
Work? What suspension are you running?
      06-07-2012, 01:50 PM   #6
DD4S
8
Drives: E90 330i
are you rubbing? what exact specs are you running? this is a perfect stance
      06-07-2012, 08:29 PM   #7
Mick J
Drives: 08 - E90 335i
Gavin@MMW would love to see more pics of your setup if you still are running the same wheels.
      06-08-2012, 10:08 AM   #8
e1001usa
Drives: 2007 335i
I like your setup
      06-08-2012, 09:28 PM   #9
Rainerelliott
Rainerelliott's Avatar
Drives: E90 328xi 2008
10.5, wow. I like
      06-09-2012, 09:11 PM   #10
Trevendous03
photographer // designer
Trevendous03's Avatar
Drives: 2006 BMW 325i E90 SG
That fitment does look perfect! I really like how flush that is. What fender work have you had done, Gavin?
