The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > custom intake
      10-20-2005, 01:02 AM   #1
BMW_E90
BMW_E90's Avatar
57
Drives: 325i
custom intake
trying to make a custom intake. cant wait
      10-20-2005, 01:03 AM   #2
BMW_E90
BMW_E90's Avatar
57
Drives: 325i
ps: any tips?
pps: pics will be posted once finished
      08-21-2006, 09:56 AM   #3
nyc3r
nyc3r's Avatar
Drives: E90
What what I have read / heard, CAI do not help much unless you match it with exhaust, fuel timing etc. They do make some noise so if you like that..
Originally Posted by slammedbimmer
is there any chance of a real CAI? i mean one that goes below to get the actual colder air (rather than the hot, engine air?) what if someone home built one that extended below, say behind the brake cooling holes in the front bumper? would that result in hp gain or be worthless?
      08-21-2006, 10:06 AM   #4
ksfrogman
ksfrogman's Avatar
Drives: E90 330i 6MT
2006 330i  [0.00]
2006 330i  [0.00]
Then you haven't seen these dynos. HP and torque gains reproduced throughout the rpm power band on two separate days:
Link 1
Link 2
The aftermarket intake utilizes a CF shield to enclose the filter element from the engine compartment. The cold air inlets toward the kidney grille extend downward on the GruppeM to allow for more scooping of cold air while the car is in motion.
      08-21-2006, 06:30 PM   #5
Chesmu
Chesmu's Avatar
Drives: 2013 X6
2006 330i  [0.00]
2006 330i  [0.00]
Now I know that warm air rises and cold air falls, but here's my question...
In the dead of summer, when asphault temps are so hig, will getting air from lower down truly get cooler air, or the hot air rising off the asphault? I ask especially because heer in Phx, the road temp will pass 120 degrees F.
"Teach the ignorant. Ignore the stupid."
      08-21-2006, 08:40 PM   #6
///Matt
United States Marine
///Matt's Avatar
Drives: 2007 Dodge Ram 1500
2006 330i  [0.00]
Road temp, on a 110 degree day, for black asphalt, is over 170 degrees F. I have measured it with a laser thermometer! That's f-in hot!
Now... temp inside an engine bay, with NO AIRFLOW is very high, several hundred degrees. WITH AIRFLOW... the average aftermarket intake that DOES NOT include a "ram air" set up like say Gruppe-M, will be getting somewhere in the area of 190 Degree F air. so... Yeah, an Outside the Car CAI will get you something... will you feel it? on a cold day, yes. on a hot day... no. Will you run a great risk of hydrolock? yes. Will an air bypass solve the hydro lock problem? yes... BUT. then you loose all the benefit of the CAI. so.... is a CAI worth it? never, in my opinion, but hey, that's just because I don't like to replace $12000 motors (PLUS labor) because I splashed through a puddle.
Matt
Search this Thread:
Advanced Search
