offset question?
10-12-2011, 07:56 PM | #2 |
369
Rep 8,693
Drives: 06 330i
horrendous offsets
10-12-2011, 07:56 PM | #3 | |
DENY THE WORLD THAT SURROUNDS YOU
505
Rep 35,580
Drives: JB 33ZERO
Rears will be tuckin a bit. Could probably get away with a 10mm spacer without rubbing with no problem as that will take you to an et33 in the rear which is def doable.
Eurocharged V5 | ROW's / CC Delete | K&N's | H&R Springs | Single Fin G.B. Grill | Mode Carbon Diffuser | JBSpeed CF Spoiler | Arkym Style CF Splitter | CF Mirror Caps | 5% Tints | 12mm Spacers | |
10-12-2011, 08:00 PM | #4 |
505
Rep 35,580
Drives: JB 33ZERO
hahahaha well yes Allen this would be a nightmare for you. However most are not pushing the envelope of width as you typically do so well.
op Allen has a point. It all depends on what you are going for. If you are looking for something that fits with some room for adjustment in width, then yes these will work. If you are looking for a flush or a bit of a poke with out the need for spacers than these are not the wheels for you. They are a bit conservative. For instance, I am running et20 in the rear, I did however roll my rear fenders a bit. So it all depends on what look you are trying to obtain. Allen has pushed the limits with poke and stretch so this set up would drive him nuts.
10-12-2011, 08:02 PM | #5 | |
M4CXG82
41
Rep 180
10-12-2011, 08:03 PM | #6 |
369
Rep 8,693
Drives: 06 330i
they will be tucked in more.
10-12-2011, 08:05 PM | #8 | |
505
Rep 35,580
Drives: JB 33ZERO
fronts will be fine.
10-12-2011, 08:06 PM | #9 | |
127
Rep 6,773
Depending on type of tire (whether they run wide/narrow) u have to be concern with rub on the suspension side...i dont know exactly how much space u have there..im sure others can chime in. |
10-12-2011, 08:09 PM | #11 |
369
Rep 8,693
Drives: 06 330i
get extended bolts. make sure they are hub centric.
why not just buy rims with the proper offset? |
10-12-2011, 08:10 PM | #12 | |
M4CXG82
41
Rep 180
tires are Bridgestone Potenza RE 050's what size tires do you recommend for the rear? |
10-12-2011, 08:11 PM | #13 |
M4CXG82
41
Rep 180
10-12-2011, 08:16 PM | #14 | |
127
Rep 6,773
My OEM RFTs w RE 050's horrible tires..but they were RFTs |
10-12-2011, 08:23 PM | #15 |
505
Rep 35,580
Drives: JB 33ZERO
I would run 235/35/19 front and 265/30/19 rear.
10-12-2011, 08:26 PM | #16 |
M4CXG82
41
Rep 180
10-12-2011, 08:33 PM | #17 | |
505
Rep 35,580
Drives: JB 33ZERO
I have ran 10mm spacers on numerous occasions with zero issues. as long as you get a spacer built buy a reputable business you should be fine. given they are installed properly with extended bolts (which typically come with 10mm spacers) and torque them down properly. people track their cars with 10mm spacers all the time. if you dont want to run spacers but dont want to look tucked... I suggest looking at a different set of wheels.
10-12-2011, 09:19 PM | #20 | |
M4CXG82
41
Rep 180
now i feel comfortable riding on spacers. i will purchase 10mm spacer. any brand you reccomend? |
10-12-2011, 09:25 PM | #21 |
M4CXG82
41
Rep 180
how about these 12.5mm spacers?
http://www.turnermotorsport.com/p-12...cers-pair.aspx |
10-12-2011, 09:29 PM | #22 | |
127
Rep 6,773
Express put me on to em... http://www.apexraceparts.com/Wheel-A...ries_c_40.html |
