19x9.5 +25 and 19x11 +25 .. need tire help !
10-10-2011, 09:49 PM | #1 |
MOE
214
Rep 2,530
If im going with 19x9.5 + 25 front and 19x11 + 25 rear, what tires should I go with? Looking for an aggressive stance, however I dont want to rub much (after of course rolling my fenders)
and for cambers, what degrees should I go rear/front? pretty much, how can we make this work thanks
10-10-2011, 10:08 PM | #2 |
47
Rep 1,007
225/35
265/35 What're you lowered on? The rears can be adjusted to -3.1 on stock adjustments. The front...depends on what coilovers you have or if you have camber plates. But..should work with -2.5 or -3...But camber you can mess around with after you get the tires on and mounted
10-10-2011, 10:22 PM | #3 | |
MOE
214
Rep 2,530
I will be lowered most probably on KW V1
10-11-2011, 12:42 PM | #5 | |
81
Rep 6,092
10-11-2011, 12:43 PM | #6 |
557
Rep 5,367
10-11-2011, 12:50 PM | #7 | |
406
Rep 3,879
You would most likely want to run a 225/35/19 front tire and a 245/35/19 rear tire to keep the stretch even and allow for the most fender clearance in the rear end. Front camber should be -1° and rear camber -2° maybe a few points more, but again this will vary depending on your suspension setup (height, stiffness, ect) |
10-11-2011, 01:00 PM | #8 |
MOE
214
Rep 2,530
Im being told I cannot run this set up and it is impossible to do so,
I may have to go at it with 19x8.5 front and 19x10 rear, 235/35 and 275/30
10-11-2011, 01:06 PM | #9 |
Pro Hater
49
Rep 1,717
10-11-2011, 01:13 PM | #11 |
MOE
214
Rep 2,530
so can I run this set up without rubbing against fenders/shock/spring?
No offense but I just want to know how you know so I can be at ease with doing it
10-11-2011, 01:17 PM | #12 | |
406
Rep 3,879
If your game, I am happy to help make it work |
10-11-2011, 03:36 PM | #13 |
Pro Hater
49
Rep 1,717
10-11-2011, 04:17 PM | #14 |
22
Rep 458
im going to preorder a similiar setup 19x9.5 +20 19x11 +25 will need stretched tires, fender roll and negative camber but it WILL work. where in la u located im going to get these wheels hopefully by end of next month
10-11-2011, 07:30 PM | #16 |
MOE
214
Rep 2,530
what set up are you running?
10-13-2011, 12:24 AM | #18 |
48
Rep 281
Here's what I've seen work
19x9.5 225/35/19 19x10.5 or 11 245/35/19 This still allows for a drop And I've never ever seen anyone running these specs with out a drop. Lol Some will still need a little camber Oh man your car is going to look sick!! Keep us posted. |
10-13-2011, 12:31 AM | #19 | |
808
Rep 5,530
