HPF FMIC.. Owners chime in.
10-09-2011, 10:21 AM | #1 |
125
Rep 1,546
I was thinking about pulling the trigger on the HPF FMIC, as i feel its best fit for me and what i want.
I wanna hear from the owners, your experiences and performance input on it. Is it worth it or not. |
10-09-2011, 12:19 PM | #2 |
My X5d tows my spec miata to the track.
74
Rep 1,254
It's a huge core and requires significant cutting. I recommend bumper removal despite what they say. They have the proper tools to modify the shroud without removing the bumper. My dremel wasn't cutting it. No pun intended.
Quality is top notch and my IATs are great. |
10-09-2011, 01:00 PM | #4 |
125
Rep 1,546
Thanks for the input! I dont mind the cutting, i really like how well its built and that it uses the stock connections which makes it a breeze for install. I know i was reading some people were scared using the stock connections might cause leaks.
10-09-2011, 01:16 PM | #5 |
74
Rep 1,254
My wgdc is fine. No leaks. HPF also did a leak test video to show they can take a lot of pressure.
10-09-2011, 01:48 PM | #6 |
125
Rep 1,546
Thanks boom, i just watched the video () looks like after all my H.w. the HPF FMIC is one of the best on the market right now for the N54. Looks like i will be a owner soon thanks guys
10-09-2011, 06:21 PM | #9 |
875
Rep 5,457
Love mine, install was pretty easy - trimming wasn't bad, only took about 30 minutes, just the plastic front shroud, but I have a small airsaw that was easy to get in there - if you need to use a sawsall, the bumper will be in the way. Mine took about 1.5-2 hours to put in - piece of cake right after the downpipe install!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
10-09-2011, 06:26 PM | #10 |
23
Rep 1,142
10-09-2011, 07:02 PM | #12 |
76
Rep 1,155
10-09-2011, 07:11 PM | #13 |
247
Rep 1,827
10-09-2011, 07:23 PM | #14 |
3441
Rep 79,211
Indeed it is and only 5.75 tall....They are nearly identical in size.
HPF uses factory charge pipe and c clips while the ETS has larger Diameter silicon piping too. Last edited by Jeff@TopGearSolutions; 10-09-2011 at 07:30 PM.. |
10-09-2011, 07:29 PM | #15 |
12
Rep 232
I own one and recommend it. Alternatively I considered the ETS 7" since I did not mind cutting but I was sold on the use of the stock quick disconnects with the HPF. In the end.. who cares. Both are quality pieces.
07 335i
12 335i 09 335i |
10-09-2011, 08:32 PM | #18 | |
5481
Rep 8,823
Alan
10-09-2011, 09:11 PM | #19 |
23
Rep 1,142
After you cut the shroud just buy about 15 inches of some boost hose and cut it in half and use the hose to cover up the trimmed areas. Makes for a nice neat install especially since the hose acts as a cover and masks the trimmed areas and also prevents it from messing with the fins when your fitting the intercooler in place!
10-09-2011, 11:55 PM | #20 |
22
Rep 575
Stock connectors are the only reason I don't like it, it's under 2 inches on the outlet I can't imagine how much back pressure it has comparing to other fmic's and the fact that it's wide it's not really good either, taller would be a better choice, I had HPF but I'm switching to AMS, I was just about to get the ETS 7 but it looks like it also has bigger pressure drop due to their fin pack style, so I'm pretty confused now with which one to go with but def. not going back to HPF unit.
10-10-2011, 02:51 AM | #21 | |
45
Rep 828
I agree with your facts,that's why I went with er! |
10-10-2011, 03:18 AM | #22 |
31
Rep 645
Question: i bought a used ets fmic. I shook it and i heard like sand in there. How do you clean it out?
BMW E92 335i
retired: 04 BMW M3 | 05 Honda S2000 | 03 BMW 330ci | 01 Honda Prelude | 99 Acura Type-R |
