TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Vanos sensor
      10-07-2011, 06:21 PM   #1
N54B30A
N54B30A's Avatar
Lebanon
224
Drives: 2021 HS M2C
Vanos sensor
My vanos sensors are going out and i looked at tischer's site but they only have it labeled "Control valve solenoid", I need both the Intake and Exhaust solenoids. My question is are they the same, do i order two of the Vanos solenoids?
http://www.trademotion.com/partlocat...&siteid=214672
2021 M2C HS DCT
2007 Wedge 335i E92 FBO, Stage 2 LPFP,VTT STG 2+, VTT Shotgun E50 w/ Inlets MT-SOLD
      10-07-2011, 09:15 PM   #2
queensfield
Drives: 2006 330i E90
They are the identical. Before you order the new ones, try cleaning them first using a spray cleaner and switching them around i.e. exhaust to intake and vice versa. I learned that from Eninty in this forum (thanks go to him for that).
      10-08-2011, 05:13 AM   #3
N54B30A
N54B30A's Avatar
Lebanon
224
Drives: 2021 HS M2C
tried cleaning them and even sea foamed them but still causing problems. I also noticed my car has been smoking a lot through the exhaust and I'm assuming thats being caused by the solenoids but idk
2021 M2C HS DCT
      10-08-2011, 05:46 AM   #4
JunkStory
160
Drives: E92 M3, 8V RS3
From what I read, if you have bad VANOS solenoids and go WOT, it will give check engine light. Or get a BT Tool to scan for codes. You might want to pinpoint the problem before spending $200 on these parts. Yes the two solenoids are same.
http://realoem.com/bmw/showparts.do?...67&hg=11&fg=15
      10-08-2011, 09:45 AM   #5
N54B30A
N54B30A's Avatar
Lebanon
224
Drives: 2021 HS M2C
i already got the codes, and I've been experiencing the check engine light and SES light, its just my car is also producing a lot of smoke so I'm wondering if thats the VANOS sensors.
2021 M2C HS DCT
      10-08-2011, 12:00 PM   #6
ShastaMan
ShastaMan's Avatar
Drives: 2009 335i E90
The VANOS unit is covered under the California emissions warranty for 7yrs or 70k miles. Do you qualify for this?
      10-08-2011, 12:14 PM   #7
queensfield
What exactly were the codes?
Perhaps there are three possibilities- vanos solenoids gone bad since you already tried cleaning and swapping, camshaft sensor itself or fuse in the engine electronics box.
      10-09-2011, 05:48 AM   #8
N54B30A
N54B30A's Avatar
Lebanon
224
Drives: 2021 HS M2C
Well they're going out because I'm pushing more hp than stock and its wearing down the solenoids. I don't think i can get them replaced by BMW because the code rarely appears
2021 M2C HS DCT
      10-09-2011, 05:53 AM   #9
tibra1
127
Drives: 2011 ZCP M3 - 2007 335i crashd
They cost $100..i would just err on the side of caution and replace...as opposed to cleaning
Part #11367585425
http://www.bmwpartscenter.net/partlo...&siteid=215996
      10-09-2011, 07:03 AM   #10
etichi
Slow,fast,slow, then you die.
etichi's Avatar
Drives: 335i 07,AA short shifter, COBB
Just went through a nightmare with mr. VANOS. I suspected correctly it was worse. In the end dealer performed oil change, both VANOS replaced, cam ledges replaced, and cleaned carbon build up. I then replaced the plugs since they didnt think it was necessary. All of this until codes stopped occurring good luck and I hope it is only VANOS.
      10-09-2011, 06:17 PM   #11
queensfield
Fuel injectors is also a possibility if you are pushing the limits
