05-02-2007, 12:29 PM | #1 |
Rep 9
2005 BMW M3 Vs 2006 BMW M3 or any other year
Are there any differences in M3's since 2001. Are all M3's since 2001 the same.
Last edited by fastnas78; 05-02-2007 at 12:30 PM.. Reason: wanting to change some info |
05-02-2007, 12:42 PM | #3 |
341
Rep 16,407
05-02-2007, 01:11 PM | #5 |
58
Rep 1,075
2006 has competition Rims
2003.5 started putting strut bar over engine (i doubt it was over the engine from 2001-2003. so with the better rims and breaks the 2006 M3 with competition package out performs other E46 M3's
ZzZzZ'er |
05-02-2007, 01:22 PM | #6 | |
529
Rep 5,498
I heard a rumor once that there was a suspension bushing upgrade or something after the first couple years to correct some mild handling quirks in the early models. Of course I only remember reading this once and it was on forum so who knows if it is accurate info.
Jason
Instagram: jellismotorwerks |
05-02-2007, 07:31 PM | #7 |
609
Rep 10,407
Suspension
I heard more rumors as well about suspension upgrades to sort out the terrible understeer on early cars. I think enigma has the details on this. Of course they did not get SMG until year 2 as well.
05-02-2007, 08:29 PM | #8 |
58
Rep 1,075
I wonder how many recalls were gonna get next year lol
ZzZzZ'er |
05-03-2007, 01:42 PM | #10 | |
//Mdicted
346
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
and along with the strut bar 2005 on up the Competion Package made available with those ZCP wheels but the year model difference are: 2001 to 2002 SMGII available In-Dash CD Player replaces In-Dash Tape Player (non-Nav cars) Bi-Xenon option replaces single Xenon Titan Shadow Trim replaces Gloss Black Trim Navigation Screen changes from 4:3 to 16:9 Topaz Blue Metallic added as standard color Automatic Headlight option 19" Wheels option added (mid year) Strut Bar added as standard equipment (mid year) 2002 to 2003 Basic Scheduled Maintenance Plan extended from 3/36 to 4/50 DSC/ABS unit moved from rear left of engine compartment under the brake fluid reservoir (leaving large empty *******. Aluminum Trim added as an option DVD Navigation replaces CD-ROM Navigation In-Dash CD Player available for Navigation equipped cars Revised HVAC controls Topaz Blue Metallic & Steel Gray Metallic dropped from standard colors Mystic Blue Metallic & Silver Gray Metallic added as standard colors LED Tail Lights (mid year) Trunk Handle extended (mid year) 2003 to 2004 BMW Assist (BMW version of OnStar) Square rear view mirror with BMW Assist and Fin at the back of the roof 2004 to 2005 Laguna Seca Blue and Oxford Green Metallic discontinued Alcantara available as a standard option Eucalyptus Malt Wood Trim available as a standard option Competition (try not to laugh) package (ZCP) added including 19" CSL "style wheels", Alcantara steering wheel and hand brake, aluminum interior trim, slightly larger (front) cross drilled rotors, M track mode for DSC, modified suspension and steering ratio, cruise control deleted. Available starting with 12/04 production. Interlagos Blue Metallic added for ZCP equipped cars only thats about what all I can think of
05-03-2007, 02:05 PM | #11 |
//Mdicted
346
Rep 9,988
but yeah for the most part all specs remained the same
General Designation: E46, M3 Coupe E46, M3 Convertible Production: 2001 on Weight Dry Weight: 3415 lbs 3781 lbs Weight Distribution front / rear: 50.1 % - 49.9 % 49.9 % - 50.1 % Engine Displacement: 3.246 cu. lt. Bore / Stroke: 3.43 / 3.58 in Max Horsepower / RPM: 333hp @ 7900 Max Torque / RPM: 262ft-lb @ 4200 Transmission Driveline: Rear Wheel Drive Types: 6 sp Manual / SMGII Gear Ratios: 1 - 4.23, 2 - 2.53, 3 - 1.67, 4 - 1.23, 5 - 1.00, 6 - 0.83, R - 3.75 Final Drive Ratio: 3.64 Brakes Type: Disk Anti-Lock Front / Rear 12.8" / 12.9" Wheels Wheels Front: 18 X 8" Cast Alloy Wheels Rear: 18 X 9" Cast Alloy Tires Front: 225/45ZR - 18 Tires Rear: 255/40ZR - 18 Performance 0-50 MPH: 3.70 seconds N/A 0-60 MPH: 4.65 seconds 5.02 seconds 0-70 MPH 6.11 seconds N/A 1/4 Mile: 13.18 seconds 13.63 seconds Top Speed 155 MPH - Electronically Limited 155 MPH - Electronically Limited Skidpad: 0.91g 0.86g Breaking 60-0: 111 ft. 114 ft. Drag Coefficient: 0.32 0.35 Fuel Consumption City/Hwy: 16/24 16/23 Dimensions Wheelbase: 107.5" Length: 176.8" Width: 70.1" Height: 54"
