Codes Thrown - No Search Results
10-04-2011, 09:26 AM | #1 |
562
Rep 3,625
Getting on the interstate this morning I gave the car about 50% throttle in third gear and it misfired and threw a SES light. The following codes were thrown:
P2DEB - ? P2ACC - ? P2AAF - Fuel Pump Plausibility P29D0 - Cylinder 4 misfire P29D9 - Misfire / Low fuel This is the second misfire I have had since installing my AP and the only ones that are consistent are the P2AAF and P29D0. The codes thrown the other time were P2AAF, P29D0, P29D2 and P29CC. I am hoping that I just need to swap out my plugs which I hope to do this evening. I assume there is almost 40k on the original plugs. Anyone have any suggestions? I am running Cobb Stage 1, Aggressive with standard throttle maps. Only mod is exhaust. |
10-04-2011, 09:29 AM | #2 |
161
Rep 7,377
yeah change plugs and see . 40K is a lot especially if you are tuned now.
10-04-2011, 10:48 AM | #4 |
562
Rep 3,625
10-04-2011, 10:49 AM | #5 |
3441
Rep 79,211
10-06-2011, 07:42 AM | #8 |
24
Rep 1,244
10-06-2011, 08:06 AM | #9 | |
562
Rep 3,625
However, those first two codes are not there at all times. It only popped up after my misfire. |
10-06-2011, 08:09 AM | #10 | |
24
Rep 1,244
That's what drives me batty about our car, I swear the DME has Gremlins inside. My battery will probably need to be replaced sooner rather than later and I want to use a lightweight one. I'm sure I'll have to do the same as you. |
