steering shakes after wheel spacer
09-30-2011, 01:59 PM | #1 |
15
Rep 275
hello fellas, i recently installed 15mm spacers all around and the front wheels are acting very unbalanced.
the wheels are OEM 125 18in and spacers H&R. Rebalance the wheels twice to no avail. Any sugestions other that remove the spacers? has anyone experience the same issue? Lou. |
09-30-2011, 02:01 PM | #2 | |
290
Rep 28,154
09-30-2011, 02:05 PM | #3 |
18
Rep 632
What speed and what type of driving? Corners? Straights? Don't assume that with the rebalanced that they did it right the second or third time. I have seen people not know how to do it in the first place and balance it wrong again and again. Kinda funny too because balance is easy. Maybe we need some pictures to look at the wheels. Are the tires new? Are they all RFT's? What is the unbalance that you are feeling? We need some more info.
09-30-2011, 02:12 PM | #4 |
18
Rep 632
22 thousand posts......... I'm pretty sure you should listen to him and not my dumb ass.
09-30-2011, 05:53 PM | #5 |
BimmerPost Supporting Vendor
2042
Rep 25,989
I would recommend double checking if the spacer is flush on the hub. Due to hub corrosion happening quite often, this might be the problem.
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
09-30-2011, 07:06 PM | #7 |
138
Rep 2,731
try cleaning hub as suggested.
if that doesnt work. troubleshoot. put rear spacers on front, and front on rear, see if imbalance persists. also... did you buy longer bolts? |
10-01-2011, 11:16 AM | #9 |
15
Rep 275
Yup hubcentric all the way. Hubs were cleaned as well. Tires are non runflats and new (less than 2k miles) and no problems once spacers are removed. Studs are longer (45mm)
Thank you all for the imput |
