09-30-2011, 10:40 AM | #1 |
57
Rep 554
Drives: 335D MSport 2016
UK 35D
I see you can now build a 35D on BMW UK. It seems to have lost power though. They are only quoting 295hp, it's 313hp on the November price list!!
Perhaps that's whey it's only 0.4 second quicker to 62mphm I always thought the differemce should have been more |
09-30-2011, 10:48 AM | #2 | |
Live for today tomorrow never comes
1990
Rep 9,498
Performance through the gears is mental.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
09-30-2011, 11:34 AM | #3 |
57
Rep 554
I know it always was listed at 313 but now it's 295 if you look on the BMW site
http://www.bmw.co.uk/bmwuk/ecom4/frameset |
09-30-2011, 01:59 PM | #4 |
Captain Unsensible
100
Rep 737
Drives: 2016 M240i Coupe - Estoril
Just add a spiderbox to the 3.0D and you're laughing
09-30-2011, 02:25 PM | #5 |
91
Rep 3,855
I wouldn't trust anything you read on the UK website. When it is actually working and not just crashing your browser (rarely), it's littered with errors and missing content
F25 xDrive20d SE __ professional multimedia package | dynamic package | climate package | 309s | xline | xenons | electric seats | folding mirrors | business speakers |
09-30-2011, 02:43 PM | #6 |
541
Rep 2,073
The original 35D engine had a small turbo for low revs and a big one for high revs to broaden the narrow diesel powerband. What does the new 35D do, is it more like the twin scroll petrol version? If so I wouldn't have thought that would work so well, except for responsiveness.
The difference between 295 and 313 hp s quite large, I remember with my E93 it was 300 in the US and 306 in Europe, this wasn't due to a different tune, it was to do with SAE vs DIN or some such thing. I think it depends on whether you measure the engine on it's own or the engine plus ancillaries but the difference is the wrong way around.....
Current: G01 M40i Silver / Tartufo
Previous: E30 318iS, E39 520i 523i 523i, E46 vert 330i 330i, E93 vert 335i, F25 30D 35D |
09-30-2011, 03:24 PM | #7 |
67
Rep 1,041
Many manufacturers still use the European "ECE 80/1269" rating system for their European ratings and the newer SAE "SAE Certified Power" standard for their North American ratings. Some simply apply a conversion factor to the kW rating to change it to HP. Many use the same rating because their engines easily can meet, or exceed, either specification. The SAE ratings include full accessory loading, inclusion of the vehicle's actual exhaust system and even a specification for having a full oil sump.
Typically, the SAE method results in a published rating that is 2% lower than the ECE rating. The original published spec for the X3 (F25) 35i was 306 PS ECE/DIN and 300 HP (SAE). Published 4-wheel dyno tests of X3 35i's have produced graphs that typically peak at around 283 HP at all (4) wheels. Correcting for an estimated minimum drive-line loss of 11 percent, that means the 35i's N55 engine actually produces something like 314 HP at the crankshaft (A/C compressor off). The other complicating factor is that the SAE specification states "...the engine must be capable of producing at least the published HP rating". The SAE Certification requires that a random sampled engine is actually "pulled" from the production line with no selection by the manufacturer. The engine can produce more and a manufacture can choose to list a lower rating if desired. This is sometimes used for marketing reasons, and/or for insurance rating purposes. One other complicating factor is that (1) European horsepower (PS) = 0.736 kW. while (1) SAE HP = 0.746 kW. Therefore 315 PS = 231.84 kW = ((1/0.746) * 231.84) = 310.8 HP. Exactly the same amount of power, just expressed via different standards. The current European practice of expressing power in kilowatts seems to be a better standard, but is still subject to differences in the way the engine is operated when the power is measured. Last edited by Lotus7; 09-30-2011 at 03:30 PM.. |
10-01-2011, 10:10 AM | #8 |
1990
Rep 9,498
http://www.bmw.co.uk/bmwuk/pricesand...-bmwuk,00.html
Look Here: States it clear enough to me, 35D = 313BHP
10-06-2011, 09:25 AM | #10 |
1990
Rep 9,498
I am not so sure about the Spiderbox, from what I have heard it just increases common rail PSI which ain't going to be good for many miles without problems, a re-map would be better IMO but I don't think the 35D will need one. The 3.0 D could be good with a re-map.
10-06-2011, 04:32 PM | #11 | |
86
Rep 510
Tony |
