2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums ASIA Rim scratch repair some pics
      09-28-2011, 12:58 PM   #1
grimlock
716
Drives: F10 N52B30@255PS
A small scratch on the rear rim, but made it through the clear coat.
Only sanded down the dirty clearcoat, did not sand through to metal. Recoat with clearcoat, re-sand and finish. You can see the damaged metal part through the smooth clearcoat. (Metal cannot be fixed unless re-machined totally, on machine face finish. Most rims are painted so would be different from this)
      09-29-2011, 01:38 AM   #2
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
2011 F10 528i  [10.00]
You made a lot of effort grimmy. Not perfect but really admire your enthusiasm. Keep it up bro.
May I know what kind of clear coat you used?
2011 F10 528i Black Sapphire / Oyster Black
2000 E46 325ci Cabrio Titanium Silver / Black - retired
1997 E36/7 Z3 Montreal Blue / Black - retired
      10-02-2011, 12:49 PM   #3
grimlock
716
It's the 2-1 mix i got with the ebay paint kit .. scratchdoctor ..not bad, better than the one from same place that come with rim repair kit. post some pics later when have chance..
      10-03-2011, 03:22 AM   #4
528imsport
528imsport's Avatar
United Kingdom
75
Drives: Msport
scratch doctor is very good some e60 members used it too.
my rims are cratch too by my dad and I just can not be othered to repaire it cos I know it will happen again.
      10-03-2011, 12:09 PM   #5
grimlock
716
Yeah, i just wanted to try to see if it can be done.. i think the shop is much better option for cost and time. Do once and maybe never again ..
scratch doctor body paint match was too dark for me, paintscratch .com was good match..
these small repairs are totally not worth the time .. just fun to try to see if u can do it
      10-04-2011, 12:18 AM   #6
Jacky328
Hong Kong
30
Drives: 535 F10
Hey Grimmy, thought I get one good place to repair rim-scratch if were my wheel scratched
2011 F10 535i Sophisto Grey/Oyster, ACS spring, Forged 1, Michelin PSS, Eisemann Quad-Exhaust,
2013 991 Carrera S PDK, Aqua Blue/Beige, PSE, PDCC, Sport Chrono Package, Paddle Shift Steering Wheel, PDLS--delivery in July2013
      10-04-2011, 12:53 AM   #7
grimlock
716
Normal shop is fine .. sure this one dun need OBD AMG CSL computer
      10-12-2011, 01:35 PM   #8
grimlock
716
Whose Eibach for 550 are those fraternizing with my rim? Nice AC Schnitzer box
      10-12-2011, 07:31 PM   #9
mlai
mlai's Avatar
Hong Kong
168
Drives: 650GC/E93M3/Lexus LS600HL
Answer is YOUR Eibach 550 springs
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
      10-12-2011, 10:46 PM   #10
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
Another fascinating project for you grimmy. Not easy, need to do a lot of things.
      10-13-2011, 11:33 AM   #11
grimlock
716
Allow me to treat your car to a tank of premium at least..
      10-13-2011, 11:54 AM   #12
grimlock
716
Yeah this one sound quite dangerous .. have to careful the coiled up spring. Will take time as usual..
Besides KW, there is also Bilstein shock for f10 .. it says paired with eibach, dun know how it would be like paired with HR, but another alternative, cost 9-10k..
I start to think improve the shock will improve the just springs, coilover advantage is both are paired/tested to work well together.. so if u match yourself trial and error /luck..
      10-13-2011, 12:59 PM   #13
grimlock
716
http://www.aze-tuning.de/gutachten/E10-20-022-01-22.pdf
Difference between eibach 523/8 and 550,
is 13.25 vs 13.5 mm wire diameter and length 318 vs 334mm length (front), same width for back 12.5mm, length 327 vs 332.
So 16mm longer (untensioned) and 0.25mm thicker on front, on back 5mm longer.
Hopefully this will result in higher ride height by at least 13mm (tensioned), as well as less dip under additional weight (cornering)
Calculated drop from OE is 17mm F, 26mm R
= slightly more than 'M' drop on front, nearly eibach drop on rear
      10-14-2011, 01:35 AM   #14
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
Bilstein is quite hard core. Don't want to be a guinea pig. May be you can try first grimmy. You are always the pioneer.
      10-14-2011, 02:45 AM   #15
528imsport
528imsport's Avatar
United Kingdom
75
Drives: Msport
Bilstein is no good for road use so don't bother testing them wast of time and money.
      10-14-2011, 10:59 PM   #16
grimlock
716
Good advice.. sounds like will def be too hard for tastes
      10-19-2011, 10:42 AM   #17
grimlock
716
So I measured the ground-to-fender height twice, with min. gas and with full gas:
low: FR FL RR RL
71.5 72.1 71.5 71.7
full
71.7 72.2 70.8 71.3
So 60L gas (=60kg) decreases rake (front-back bias) by raising front ~1.5mm and lowering back ~5.5mm
Can't help to think car is set up perfectly for LHD (for only driver).. too bad ours is RHD
Will need to measure the springs when removed from car, to see if the difference comes from there. If so, the problem is known, if not, will have to consider 5mm-10mm pads.. will need to research which materials best.
Eibach Springs L/R are deviating by 2mm untensioned (may be different under tension)
Final goal is L/R level with no driver, or up to +5mm raised in FR(driver)
5post
