Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > E90 LCI - ET35 Up front - Anyone running more aggressive lowered?
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      09-28-2011, 12:22 PM   #1
cssnms
cssnms's Avatar
Drives: 2011 BMW 335d
So I am running 19x8.5 et35 up front on a 225/35 series tire. I am lowered, fenders are not rolled, would prefer NOT to. No rubbing and the clearance in the wheel well seems tight esp when I crank the wheel the whole way, but again not rubbing. My wheel still seems a little tucked, just wondering if anyone is running a similar set-up with a more agressive off-set on a lowered car, w/no roll? If so, what specs and do you rub at all?
Thank you
      09-28-2011, 12:30 PM   #2
NiVeDh
NiVeDh's Avatar
Drives: '08 E90 335i, '99 E36 M3
19x9 ET31 with 245/35. Lowered. No rub. Flush.
      09-28-2011, 12:38 PM   #3
cssnms
cssnms's Avatar
E90 right? Are your fenders rolled? Any modifications to the wheel well?
I just don't see how that could fit esp considering the tire size and wheel width! I can barely get my finger between the wheel well and my tire when I crank the wheel the whole way over.
      09-28-2011, 01:17 PM   #4
NiVeDh
NiVeDh's Avatar
E90. The front fenders are not rolled at all and no modifications. I have Bilstein PSS9's, set to the highest setting (which is still extremely low). Camber is set to -1.0 degree.
      09-28-2011, 01:22 PM   #5
NiVeDh
NiVeDh's Avatar
Here are some more photos showing the front wheels in detail: http://www.e90post.com/forums/showthread.php?t=527634
      09-28-2011, 01:46 PM   #6
cssnms
cssnms's Avatar
I appreciate the feedback. Can't view the photos from my work computer for some reason, but reading through your posts it appears you are rubbing up front.
I have not rolled the fronts yet. It rubs very, very rarely on the front with the Bilsteins set to the max height (even max height is extremely low). I do have the fronts set to the max negative camber possible (alignment pin punched out, no camber plates). I might roll the fronts when I get a chance.
I would guess I might be able to get away with a 5mm spacer up front.
      09-28-2011, 02:15 PM   #7
info@VMRWheels
BimmerPost Supporting Vendor
info@VMRWheels's Avatar
31
Drives: BMW
A 5mm spacer could work for you because of your tire size. We recommend a 235 for a 19x8.5 so since you're running a slightly narrower tire you could space the wheels out a tad.
      09-28-2011, 02:19 PM   #8
NiVeDh
NiVeDh's Avatar
That rubbing was with a bad alignment. The shop did not set the camber properly (they had one side set to -0.6 and one side set to -0.9). After going up to -1.0 for both, the rubbing went away.
      09-28-2011, 03:04 PM   #9
cssnms
cssnms's Avatar
Thanks Kevin, but now that you mention it, I think I am running a 235/35, sorry for the confusion. Do you still think that would be okay?
      09-28-2011, 03:12 PM   #10
info@VMRWheels
31
Drives: BMW
With a 5mm spacer you still might be able to pull it off. I can't guarantee it though since it isn't exactly our recommended fitment with the added spacer.
      09-29-2011, 04:55 PM   #11
Pcemkr
Pro Hater
49
Drives: Low and slow
You can run 9.5" et20 with a 225 and not rub.
      09-29-2011, 05:23 PM   #12
cssnms
cssnms's Avatar
Et20??? Are you running this offset? Pics?
      09-29-2011, 05:37 PM   #13
tofu-
87
Drives: 335i Jet Black/Coral Red
i may try 19x8.5 245 et23 once i do the m3 front control arm conversion. hopefully there will be enough camber
      10-05-2011, 03:56 PM   #14
mrj25
mrj25's Avatar
Drives: 2011 335i E90 LCI
I'm currently running a 235/35 nitto nt555 19x8.5 et23 (with 10mm spacer) up front with no rubbing and lowered on the Eibach Pro Kit, OEM Performance Shocks and SP Perch. I'll post a close up pic later tonight.
      10-05-2011, 04:13 PM   #15
Pcemkr
Pro Hater
49
Yes. I have 18x9.5" et19 225/40 and do not rub.
      10-05-2011, 04:46 PM   #16
cssnms
cssnms's Avatar
I apprciated all of the replies and input. I am leaning towards trying the MS 5mm spacers sold by eas.
Depending how the fronts go may try 3mm spacers in the back running with
a 265/30 series tire.
      10-06-2011, 07:50 AM   #17
BMWsky
Drives: 335i
Fuzzy Dice????
      10-06-2011, 05:06 PM   #18
cssnms
cssnms's Avatar
Fuzzy dice???
      10-10-2011, 11:40 AM   #19
cssnms
cssnms's Avatar
Woudl love to see those pics! I am runnign the same wheel/tire size and suspension set-up and I just don't see how et23 would work unless your fenders were pulled/rolled.
      10-10-2011, 11:55 AM   #20
cssnms
cssnms's Avatar
mrj25 found this post/pics of your car running et34 w/5mm spacers. guess this was before you up-sized your spacers. so you didn't get any rubbing on the fender liner when going over dips or when you cranked the front wheel as far as it would go?
As promised, I finally got my eibach pro's installed with performance dampers and SP perches! The ride is a definite improvement and the springs provide a noticeable drop. My wheels are 19x8.5 et34 front and 19x9.5 et34 rear with a 5mm spacer which makes it et29. There is no rubbing and the ride is perfect. Here's a few pics taken this morning
      10-10-2011, 03:11 PM   #21
mrj25
mrj25's Avatar
No rub in the front and rear at all. I upsized the front to a 10mm and the wheels do not poke out as aggressive as I thought it would. I tried having the 10mm on the rear but it rubbed as I do have the fenders rolled. It looked really nice but I needed a ride that felt comfortable so I experimented the 10mm up front and put the 5mm on the rear and so far so good. I had 2 passengers in the rear and 1 up front and no rub at all. Here are pics I took just right now at the park. Excuse me for my wheel center caps as I do have custom vinyl black overlays on the way for my Varrstoen 1.1.2.
Front
Front Passenger
Passenger Side
Front Driver
Rear
      10-10-2011, 05:15 PM   #22
cssnms
cssnms's Avatar
Thanks for the pics. So you say you are rolled in the back or was that a typo? If you're rolled I won't likely be able to fit 5mm in the back then since I am not rolled and I have no plans to roll. Maybe could get away with 3mm in the rear.
What brand spacer are you running? Any vibration issues at speed?
BTW, your car looks great!
