Spacers for Alufelgen CS7s on E92/93?
09-28-2011, 08:26 AM | #1 |
187
Rep 1,677
Is anyone running spacers in the rear with Alufelgen CS7s on their E92/93?
The fronts are so nice and flush that the rears look a bit tucked now, although they are a great improvement over stock. I have a brand new set of Macht Schnell 12mm that I bought to use with my stockies before I decided on the new rims. I was about to return them when I saw that there was some room in the rear. Any ideas how wide I can go? Guys from Alufelgen or **********s?
2008 Montego "330i" /3.0 manifold /AA /Eurobox /PE /Alufelgen CS7 /Macht Schnell /Michelin PSS /XPel
"O thou afflicted, tossed with tempest, and not comforted, behold, I will lay thy stones with fair colours, and lay thy foundations with sapphires." (Isaiah 54:11) |
09-28-2011, 12:23 PM | #2 | |
171
Rep 2,057
09-28-2011, 12:40 PM | #3 | |
208
Rep 3,175
09-28-2011, 12:45 PM | #4 |
187
Rep 1,677
Thanks. Doin' the "highly technical" index finger test, it looks like you're right...10mm at the most (halfway to first knuckle or 1/2 inch/about 10mm). 5-8mm would be more like it, as you suggest.
Not sure it's worth introducing another variable for that kind of gain. They look pretty darn good as is!
09-28-2011, 03:13 PM | #5 |
171
Rep 2,057
We have done 5mm in the front with no issues. It all will depend on the tire brand, size and the suspension setup.
09-28-2011, 03:29 PM | #6 |
208
Rep 3,175
Matt I am running Conti DWS, 235/35 series tires up front. What do you think? It's doesn't seem like there's a lot of clearance between my fender liner and my tire when I crank the wheel over. Guess I would more concerned with rubbing on the fender itself though.
09-28-2011, 11:17 PM | #7 |
475
Rep 13,583
Drives: JB E92 335i
5mm spacers in the front and the rear will push the wheels out just a bit. It will be safe without a fender roll. You can also add 10mm spacers if you're looking to go a bit more aggressive, however, this may cause rubbing issues which can be solved by a fender roll!
09-29-2011, 10:55 AM | #8 |
153
Rep 3,730
When I had CS7's I used 10mm all around (19x8.5 19x9.5 et35) and was nice and flush with no rubbing on my HR sports. That worked well with Falken 452's but when I switched to Pilot Super Sports the rears were too beefy and removed the spacers, 10mm front and 5mm rear works.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
09-29-2011, 05:38 PM | #11 |
208
Rep 3,175
Thanks Alan will check them out.
Btw, that Hamman lip I just got from you fits and looks knarly on my e90 lci. Can send pics if interested. Any other spacer suggestions? |
09-29-2011, 05:50 PM | #13 |
208
Rep 3,175
09-29-2011, 06:11 PM | #14 |
87
Rep 2,854
09-29-2011, 07:37 PM | #16 |
87
Rep 2,854
09-29-2011, 08:05 PM | #17 |
153
Rep 3,730
Here's a shot of my old CS7's in gunmetal with 10 mm spacers on HR/Koni Yellow suspension.
09-30-2011, 05:55 PM | #18 |
208
Rep 3,175
10-01-2011, 04:27 PM | #19 |
153
Rep 3,730
^ H&R 10mm on all four. They are hubcentric and no rubbing with Falken 452's....but they do rub in the rear with my beefy PSS's, 5mm spacer would fit with those tires.
