Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Help with new rims
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      09-27-2011, 02:44 PM   #1
williewonkerz
williewonkerz's Avatar
60
Drives: M235i
2014 M235i  [0.00]
Help with new rims
I have a new 335xi Special Edition coming and sadly by the time it gets here I'll very quickly have to swap out the rims for winter tires and rims
I'm looking at some VMR VB3 in this size:
18x8 +38 offset
And planning on putting some 225/40 R18 Michelin X-Ice2 NON RFT.
Will this setup work? I'm just never sure about the offset in particular. The car is coming with 225/35-19 front and 255/30-19 (I believe).
      09-27-2011, 04:30 PM   #2
SWFan
Drives: 2011 335is
I believe common wisdom has been 17" wheels for winter driving with all four of the same size, not staggered. 17" wheels are slimmer and thus plow through snow more easily than 18". Staggered is a no-no for basically the same reason, bigger back tires means harder to plow through the snow.
And on an XI; unless things have changed I didn't think BMW recommended staggered set ups for an AWD models. At least in the E46's that was the case.
      09-27-2011, 05:40 PM   #3
DDS2015
393
Drives: 2018 M3CS
2021 BMW X3  [0.00]
2023 BMW M4  [0.00]
I'd also say go with the square 17's. Hit up tire rack. It'll show you exactly what you can use. Also, when do you get the car? I pick up my E90 on October 8.
      09-27-2011, 06:01 PM   #4
VMRWheels
BimmerPost Supporting Vendor
VMRWheels's Avatar
2042
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
The wheel should be a 18x8.5 +40. If so, then 225/40 is perfect.
-Charles@VMRWheels
      09-27-2011, 08:40 PM   #5
jldec16
Drives: RS5, C63 COUPE, Q7, 335i
that's work
      10-05-2011, 07:47 AM   #6
williewonkerz
60
Drives: M235i
2014 M235i  [0.00]
-Charles@VMRWheels
What if the rims were 18x8? Would a 225/40 still work, or I would need a "slimmer" tire?
      10-05-2011, 09:12 AM   #7
Patrick303
Patrick303's Avatar
Drives: F36 440i GC
Things have changed then. My e92 xi came stock with 18" staggered wheels. And while wider and larger wheels may not be ideal for winter, they still work fine. I use my 18" staggered stock wheels during the winter and some 19" staggered ones for summer.
2024 Porsche Taycan 4S
2017 Ducati Monster 821
      10-05-2011, 12:35 PM   #8
VMRWheels
VMRWheels's Avatar
2042
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
A 225 would still work perfectly fine.
      05-09-2012, 12:26 PM   #9
ronmeister
ronmeister's Avatar
10
Drives: 11' 335i Xdrive
I'm trading in my 07' 335xi for a 11' SE. DILEMMA: I have SWEET 19" OEM 3-PC w/run-flats that are near life-end AND 18" Stock sport wheels with Hankook Ice Bears for winter (newer).
I will absolutely need winters on the new 335 and it will come with 19" R-craps so I'll have summers, but do I trade my 07' with the sweet 19"s and then just use my existing 18" winters?
Or should I trade it with the 18" winters and keep the sweet 19"s, buy new Blizzaks at $1500.
Point: I'm not getting any extra value for the trade with the sweet 19"s...so I don't really want to give them to the dealer.
Counterpoint: While I love the 19" 3-pc wheels...I'm not sure running 19" Blizzaks (235/35/19) is the best winter option.
Thoughts?
