Ridiculously uneven tire wear w/ pics
09-25-2011, 09:34 PM | #1 |
40
Rep 333
Hey guys--I need help diagnosing this absurd wear on my front passenger side tire only. Basically the inside edge has been indented inwards, almost by a full centimeter, and the outside edge is nearly bald. The middle of the tire probably has 4-5/32" of tread left.
I initially thought bad alignment was the culprit, but could this be due also to a suspension issue? All other tires are wearing equally. Any thoughts are appreciated. |
09-25-2011, 09:53 PM | #2 |
448
Rep 2,032
Drives: Red Flyer
There's no way that indent could be caused by wear... It almost looks like the tires have been stretched to fit the rim.
09-25-2011, 09:54 PM | #3 |
138
Rep 2,731
something is rubbing and causing that "indentation".
the bald outer part is due to camber and possibly toe, your car should have negative camber. when you buy new tires get a lifetime alignment at firestone. if the middle has a lot of meat and both outer edges are worn then your tire pressure may be too high. what psi are you running them at? Are these stock size tires? what size are they exactly? lowered? not my pic and not our cars but are you rubbing here... Last edited by mike3000fl; 09-25-2011 at 10:20 PM.. |
09-25-2011, 09:56 PM | #4 | |
40
Rep 333
BTW this is an 08 e92 335i with SP, so tire size is 225/40/18, completely stock. Last edited by badassfajita; 09-25-2011 at 10:40 PM.. |
09-25-2011, 10:10 PM | #6 |
Very Important
20
Rep 450
Drives: 335xi (e92)
Garage List 2008 BMW 335xi (e92) [9.00]
2008 Pontiac G8 GT [4.00] 2002 Pontiac Grand ... [0.00] 2001 Cadillac, Eldo ... [0.00] |
The outside area of those Potenzas will wear fast, as designed and even faster if out of alignment/under pressure.
I'm not sure what's going on on the inside... Fill us in. |
09-26-2011, 09:08 AM | #8 |
148
Rep 1,728
Take that tire off and snap some more pictures of the tire from different angles. I have never seen this before. Take a look inside that wheel well for anything out of the ordinary.
I wonder if this is a defective tire?
'11 Space Grey E92 335xi M-Sport (KWv1 Coils | Saddle Brown | Bamboo) (Returned)
'14 Mineral Grey F32 335i M-Sport (Dinan DHP | LED Lights | Coral Red | Hexagonal Aluminum) (Returned) '16 Mineral Grey F80 M3 ZCP |
09-26-2011, 11:44 AM | #9 |
1448
Rep 1,720
09-26-2011, 11:56 AM | #10 | |
BimmerPost Supporting Vendor
2042
Rep 25,989
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
09-26-2011, 05:06 PM | #12 | |
6659
Rep 15,858
Normally do this on the rear, it is NOT rubbing anything. Pressures on the low side and alignment issues, can cause this to happen very quickly indeed. Partly caused by running on the sidewall, and as the tire wears, the carcass distorts even more, where the sidewall joins the crown of the tire. HighlandPete |
09-26-2011, 06:08 PM | #13 |
668
Rep 7,148
never seen anything like this before...
2016 F80 M3 Mineral White/Sakhir Orange
2013 BMW S1000RR Flat Silver <stolen> 2007 BMW E92 335i Jet Black/Jade Grey <sold> |
09-26-2011, 07:51 PM | #14 |
17
Rep 415
This is pretty extreme. I wonder what your wheels look like from a side view. I bet they make your car look like its standing on tippy toes.
09-27-2011, 03:47 AM | #15 |
6659
Rep 15,858
The first picture is typical rear inner wear of a RFT, no alignment issues, just normal wear with BMW settings, and running a higher than door placard pressure setting. But the beginnings of the grooved wear.
This is typical of the wear we do see on the rear, sport settings and running low pressure, mean this is quite common. This issue is discussed quite often here in the UK. A well respected tire and suspension specialist, WIM (Wheels in Motion) come across this quite often. A combination of camber, tyre stiffness and pressure, allow extreme distortion around the tyre junction of wall and crown, marked on the drawing (A). Once the structural tread 'bridge' begins the wear the tire is weakened, distorts even more, and the wear accelerates. The stiffened sidewall cannot distort enough to share the load, so the load is very local to the junction. HighlandPete |
09-27-2011, 10:44 AM | #16 |
1569
Rep 29,202
Never seen an "indentation" like that before.
09-30-2011, 05:27 PM | #17 |
40
Rep 333
Update: Got rid of my RFTS and went with new Pilot Super Sports. Had my suspension checked out and they could not find anything rubbing against the old tire. I did get my car aligned at an indy with a Hunter Hawkeye Laser machine, and the toe was way off on that wheel as well as on both rears. Steer ahead and thrust angle were also out of spec.
Too early to post comments on the tires, but initial feedback is less than great. Steering seems overly soft. Running 32/37 psi. But have only driven 3-4 miles. |
09-30-2011, 07:20 PM | #18 |
138
Rep 2,731
bear in mind... with your car being so far off on toe, the "soft" steering you feel may be more to do with the new alignment than the tires.
non run flats do feel softer though than RFTs generally. |
09-11-2016, 02:56 PM | #19 | |
32
Rep 209
Thanks in advance. |
09-20-2016, 02:31 PM | #20 | |
453
Rep 2,973
Now running higher pressure on the new tires AND got an alignment.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
