Camber plates... which to get?
09-25-2011, 03:28 PM | #1 |
Cone Killing E90
42
Rep 698
Drives: 19 X3 M40i
What's the difference between the Ground control, the Vorshlag and say the staged KMAC sets sold by Turner?
I autocross my car about twice a month from March until November. What I'm looking for is a set of camber plates so that I can adjust camber with minimal tooling. I currently have H&R sport springs on oem sport struts / dampeners along with TR motor sport wheels in 18x9 with Dunlop Direzza Z1 Star specs all around. I have rolled my front fenders however where the front bumper meets the fender I am experiencing some rubbing on large bumps or dips in the road. This is going to get worse until I change out the oem struts / dampeners of which I plan to do early next month for a set of Koni Yellow's. I'd like to get the camber plates as well to tune in some negative camber. I also daily drive my car to and from work on the oem sport wheels so whatever camber plates I buy need to be strong enough to handle that beating from the not so great roads around Norfolk, VA... Looking at the HP autoworks listing for the Vorshlag plates, they give two options for Koni's in the "strut type" pull down menu, so I'm a little confused about that as well: http://hpashop.com/product.sc?produc...categoryId=175 The Turner / KMAC sets: http://www.turnermotorsport.com/c-64...er-plates.aspx and the Bimmerworld Ground Control sets: http://store.bimmerworld.com/ground-...tes-p1543.aspx And Thank you for the help! |
09-25-2011, 10:57 PM | #2 |
127
Rep 6,773
Without a doubt go w HP Autowerks and the Vorschlags..The Vorschlags are proven..and Harold is one of THE most knowledegable suspension guys I have spoken to..
You can check out my review..I purchased my entire suspension from Harold at HPA. http://www.e90post.com/forums/showthread.php?t=586764 |
09-27-2011, 04:31 PM | #3 |
pew pew
166
Rep 6,781
I have static Dinan plates, but they only give you a small amount of increased negative camber and it increases your stackup height by about a 1/4". Works great for me though as there are no moving parts and really nothing to wear out or break or cause noises.
CSL replicas are now CSL counterfeits. Jesus saves, like Valentine1.
09-27-2011, 04:42 PM | #4 |
153
Rep 3,730
+1
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
09-27-2011, 05:07 PM | #5 |
just another bmw douche bag
195
Rep 3,640
Ground control has a street camber plate and a race plate. The street ones retain a rubber bushing to help isolate noise/vibration/harshness, while the other does not. Something to consider if it's your daily driver.
some camber plates may also lower the car more than stock because of the way the top mount is designed, so you might want to check on that as well, since you aren't running coilovers. |
09-27-2011, 08:29 PM | #6 |
48
Rep 842
How much negative chamber are you getting by just throwing on H&R springs? Without camber plates?
2006 325i: Matte Black Grills, AG m310 19's (19X8.5et35 & 19X9.5et33 - 235/35/19 & 265/30/19), Amber Covers, Magnaflow with black tips, Blacked Emblems, M3 Replica Bumper and Vorsteiner hood! |
09-28-2011, 05:16 AM | #7 |
79
Rep 1,617
Changing springs will not affect camber on the front at all.
Performance Seats, Exhaust, Splitters, Pedals, Steering Wheel / RB Turbos / M3 CF Roof / Brembo GT BBK 355/345 / Rollcage / Forge FMIC / Quaife LSD / Öhlins Road & Track / M3 Suspension Parts / Solid Subframe Bushings / Vorshlag Camberplates / Megan Racing Toe Links / LeatherZ Gauges / Extended M3 DCT Paddles / ER Sports OC / AR OC / Aux Radiator / AR DPs / Alpina TCU / COBB Pro-Tune
09-28-2011, 05:41 AM | #8 |
37
Rep 2,084
Can anyone comment on the TC Kline camber plates? I remember someone said they're the easiest to adjust between track and street settings. Is there any downside compared to Vorschlag?
09-28-2011, 10:30 AM | #9 |
48
Rep 842
....... Wow I'm confused now. So you're saying lowering your car does not cause negative chamber? That's totally against everything I've learned
09-28-2011, 10:40 AM | #10 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
The downside to the TCK plates is that it must be used with a TCK/Koni coilover set up. |
09-28-2011, 01:36 PM | #11 | |
195
Rep 3,640
front a-arm suspensions (like on my honda, miatas, S2000s) will gain camber when lowered. |
09-28-2011, 03:33 PM | #12 |
Cone Killing E90
42
Rep 698
Drives: 19 X3 M40i
On your site, Is this what the difference is betweeen the two "Koni" options under the strut type option: Koni Tapered vs TCK/Koni?
09-28-2011, 04:22 PM | #13 |
3847
Rep 54,376
Drives: F80 M3
09-28-2011, 04:26 PM | #14 | |
Cone Killing E90
42
Rep 698
Drives: 19 X3 M40i
Thanks!
Also, b/c I autocross, I'm also starting to consider coilovers, but I'm not sure if coilovers would bump me out of STU class (SCCA rules). Do the springs in the rear for a coilover setup sit in the oem spring perches or do they surround the strut like they do in front? The SCCA Solo Street Touring suspension modification paragraph: Quote:
09-28-2011, 04:37 PM | #15 | |
3847
Rep 54,376
Drives: F80 M3
09-28-2011, 04:56 PM | #16 |
The Law.
301
Rep 14,283
Harold,
What are the benefits of GC plates using completely solid, separate bearings for the spring and strut versus "traditional" camber plates that use single bearings to support the load? |
09-28-2011, 06:48 PM | #17 |
15
Rep 101
SPC performance camber plates
Wondering if anyone has run or know anything about the SPC performance camber plates???
I am running the Eibach R2's up front and was missing part of the SPC kit originally so I didnt install the camber plates, however got the missing plates now and wondering if there is any feedback on these camber kits??? |
09-28-2011, 07:43 PM | #18 |
48
Rep 842
So can those vorshlag plates be put on the back shocks? I ordered knoi shocks and H&R springs not knowing I'd need camber plates to reduce the camber in the back.
09-28-2011, 08:25 PM | #19 |
Cone Killing E90
42
Rep 698
Drives: 19 X3 M40i
09-28-2011, 08:49 PM | #20 |
48
Rep 842
AhA! life is starting to make sense now!
09-28-2011, 08:58 PM | #21 |
195
Rep 3,640
10-06-2011, 07:42 PM | #22 |
Rep 79
+1 Would like to know as well.
2016 BMW S1000RR - BrenTuning - Akrapovic - Attack - Rizoma - Graves 2009 E92 335I / 6MT |
