XI to I
09-24-2011, 02:16 PM | #1 |
7
Rep 167
XI to I
I have an XI was wondering if anyone took off the tcase and called it an I or is much more complicated then that? I did a very minimal search but came up empty the reason I ask is my tcase seems to be going out and cant dish out the money for a new one.... I also prefer rwd that is after the winters of course...
09-24-2011, 03:01 PM | #2 |
Guardian of the Night
109
Rep 1,831
Drives: 2010 335i M Sport Coupe
I didn't realize that was even possible...
2010 335i M Sport Coupe -- Black Sapphire Metallic|Coral Red|Loaded|JB4 Stage 3|BMS DCI|VRSF DPs|Camaross 6k AE|Performance Gloss Black Grilles|CF Performance Spoiler|CF Quad Diffuser|Double Layer Black Chrome Quad Tips|CF Roundels|Smoked Reflectors|Red Cyba Scoops|193s Painted Lamborghini Metallic Dark Gray
09-24-2011, 03:06 PM | #4 |
319
Rep 1,023
So you want to make your XI rear-wheel-drive? I would guess it's much more complicated than modification to the transfer case, if you want to retain all the BMW computer stuff.
Specific to your question, I'm not sure if you can just remove the transfer case and be ok. I would guess no, but that's not based on anything e90-specific. |
09-24-2011, 03:11 PM | #5 |
393
Rep 1,444
Drives: 2018 M3CS
Well, if you do it here's what you'll need to do, and there may be more than this yet:
A longer drive shaft to the rear diff. Get rid of the drive shaft to the front diff. Cap off the front diff (but make sure you still have oil in it). Do a whole bunch of coding and reprogramming to the computer. Think of all the systems that use the awd system (engine management, traction control, etc) Probably want to drop the suspension. All of this would cost a lot more than replacing the tcase. You'd be much better off getting a used one and doing a diy repair. If you can't do that, then trade the car in (if you can't afford to fix it that is). Shouldn't this be the type of thing covered by warranty? |
09-24-2011, 03:40 PM | #6 |
40
Rep 2,431
Sell the car before the Tcase goes and get an I
My speeding isn't the problem. It's the Slow Folks ahead of me that cause accidents!
09-24-2011, 03:42 PM | #7 |
Where'd my VTEC go?
481
Rep 6,067
mechanically, yes that would technically make your car RWD if no power is being sent to the front. electronically, i'm sure the car will freak out and things wont work right.
09-24-2011, 04:49 PM | #8 |
130
Rep 2,489
Drives: 2007 E92 SG 335i 6MT
09-24-2011, 05:40 PM | #9 |
Bavarian Fever
34
Rep 1,108
| ESS n52 Tune | BMW Performance Intake/Exhaust | LUX H8 v3 AE | GP Thunder 8500K fogs/corners | LED: signals/interior | V1 hardwired | debadge | AC pedals | Performance shift knob/boot | CF e-brake | Aero lip | m3 side skirts/spoiler | MB kidneys | Strut brace | Painted reflectors | Painted Calipers/Hubs | 35% 3M tint | Smoked tails | CF Roundels | 19" Miro 942 | Conti DWS | H&R Springs for xi | Bilstein Shocks| Nxt: Alpine Subs/Amps
09-24-2011, 06:43 PM | #10 |
180
Rep 2,446
Drives: '11 E92 M3 DCT
Just pull the 26 fuse and call it a day!
11' E92 M3 Space Grey | DCT | ESS VT2- 625 | Gintani Race (valved) + Quad Res Catless X-Pipe | KW Sleeve's | GC Camber Plates|Arkym Diffuser | Vorsteiner VRS Lip | P3 Boost Guage | Stud Conversion PHOTO's: Click Here ESS VT2 625 PHOTOS: Click Here |
09-25-2011, 08:06 PM | #17 | |
Rep 73
