Castrol SRF Racing Brake Fluid
09-23-2011, 11:12 PM | #1 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Since there is no thread on one of the best brake fluid available to us, I'll start one...
Race Proven - Ultimate Racing Brake Fluid! CASTROL SRF Racing Brake Fluid is an ultra high performance product formulated specifically to satisfy the ever increasing stresses placed upon the braking systems used in international motorsport. The exceptional performance of Castrol SRF is due to a novel silicon ester technology pioneered by Castrol and unique to the extent that it has been granted patent-protection in numerous countries throughout the world. Castrol SRF Properties Exceptionally high dry boiling point of 590ºF (Wet 518ºF) Superior anti-vapor lock properties Safe for all non-mineral oil-based disc and drum brake systems Exclusive European formula! Exceeds SAE 1703, ISO 4925, JIS K2233, FMVSS No. 116 DOT3 and DOT 4 Castrol SRF Brake Fluid Technical Information Castrol SRF Racing Brake Fluid is an ultra high performance product formulated specifically to satisfy the ever increasing stresses placed upon the braking systems used in international motorsport. The exceptional performance of Castrol SRF is due to a novel silicon ester technology pioneered by Castrol and unique to the extent that it has been granted patent-protection in numerous countries throughout the world. Castrol SRF evolved as a direct result of Castrol's ongoing Research and Development program for brake fluids which identified this silicon ester technology as providing considerable performance benefits when compared with conventional glycol ether borate ester fluids. Following exhaustive laboratory tests at Castrol's International Technology Centre in the UK, the final formulation for Castrol SRF was subjected to an extensive road-test programme on the Gross Glockner and Stelvio passes high in the Austrian and Italian Alps. It then underwent an independent track test program conducted by a famous Formula One racing team. Their assessment was that "Castrol SRF is the best racing brake fluid we have ever used." Subsequently, Castrol SRF was offered to top flight racing and rally teams throughout the world including most of the Formula One teams, the all-conquering Jaguar and Mercedes -Benz sports car teams and the Audi, Nissan and Toyota rally teams. Enthusiastic recommendation by these experts soon created an immense interest in Castrol SRF throughout the whole spectrum of national and international motorsport. Today, Castrol SRF is regarded by the international motorsport community as being without equal and it is chosen not only by factory-supported teams but by private competitors throughout the world. All conventional brake fluids used in cars and motor cycles are hygroscopic, that is, they absorb water from their surroundings. Strange though it may seem, the flexible hoses incorporated in braking systems are permeable to water and in time enough, water can find its way into the system via the hoses, and seriously affect the brake fluid's performance. This water reduces the boiling point of the fluid (ie, it lowers the temperature at which gas bubbles begin to form). When these bubbles form, they turn a virtually incompressible liquid into a mixture of gas and liquid which can be compressed quite considerably, thus severely reducing the efficiency of the brakes. In this situation, a driver finds that the brakes feel spongy. Brake-pedal travel will increase and it may be necessary to 'pump' the pedal to get the brakes to function effectively. However, when the brake fluid reaches a temperature at which the water in the fluid causes gas to be produced, which is equal to the volume swept by the piston in the rake master-cylinder, vapor-lock occurs and the brakes become inoperative. When this happens, the first indication the driver has that something is wrong is when he applies the brakes. The pedal goes down to the floor and the car carries on at undiminished - and possibly fatal speed. The silicon ester technology in Castrol SRF addresses this problem in two ways. Firstly, Castrol SRF is less hygroscopic than conventional brake fluids - it absorbs less water in a given time. Secondly, unlike conventional glycol ether fluids, Castrol SRF reacts chemically with the absorbed water to reduce its adverse effects, thus preventing the fluid's high temperature performance and safety margins from deteriorating as rapidly as they would otherwise do. Castrol SRF exceeds the US Federal Standards FMVSS 116 DOT 3 and DOT 4, ISO 4925, JIS K2233 and current SAE J1703 and is miscible with all conventional brake fluids conforming to these standards. However, mixing Castrol SRF and conventional brake fluids will reduce the benefits of Castrol SRF. It is strongly recommended that conventional brake fluid be drained from the system before flushing and refilling with Castrol SRF. The wet boiling point of Castrol SRF, 270 C, is vastly superior to the minimum requirement of 155 C demanded by the current US DOT 4 specification. The product's typical dry boiling point of 310 C is likewise outstanding. This ability to withstand temperatures in excess of 300 C, and its superior resistance to the effects of absorbed water, have established Castrol SRF as the world's premier fluid for the hydraulic brakes used in all forms of motorsport. |
09-24-2011, 01:15 AM | #3 | |
3847
Rep 54,376
Drives: F80 M3
http://www.hpashop.com/category.sc?categoryId=188 |
09-24-2011, 02:39 PM | #4 |
LCI'd
257
Rep 819
Have you read the BMW TIS regarding brake fluids? It states no synthetic fluid can be used, only mineral... If you have some other info, please share.
Castrol SRF is undoubtedly a great fluid, but I wouldn't want to mess something up.. |
09-24-2011, 10:47 PM | #5 | ||
3847
Rep 54,376
Drives: F80 M3
Once again, please read my post. I said "one of the best..." Although RBF is great, you will need to flush it out often to keep it its optimum performance levels. Its wet boiling point is no where near the SRF. In the long run, SRF will save most people money and time. If you still use rubber brake hoses, SRF is your friend. Last edited by HP Autosport; 09-25-2011 at 11:15 PM.. |
09-26-2011, 01:01 PM | #9 |
3847
Rep 54,376
Drives: F80 M3
09-26-2011, 02:45 PM | #10 | |
548
Rep 5,695
FYI here is a link from another thread that gives wet and dry boiling points for a number of brake fluids: http://www.1addicts.com/forums/showt...=573222&page=3 |
09-26-2011, 02:54 PM | #11 | |
3847
Rep 54,376
Drives: F80 M3
For those don't have the deep pockets, the SRF is the way to go, as you just need to bleed it before each event to ensure no air is present. |
01-13-2014, 11:10 PM | #13 |
Guest
Rep n/a
Drives:
Motul fluid is good, SRF is better. Also a lot more expensive.
01-16-2014, 01:53 AM | #14 | |
Evo Junkie
35
Rep 157
I've used Motul RBF600, 660, ATE Superblue, AP600 and Castrol SRF in my 750bhp Evo6 race car, and the SRF blows all the others into the weeds in regards to ultimate performance. It's the wet boiling point which makes the big difference, as a fluid will start absorbing moisture as soon as the bottle is opened. In a full weight 500hp Evo 9 which I used to test/develop my custom Porsche brake kit, the SRF was the only fluid not to cause a soft pedal when the brakes were pushed to the limit in regards to disc temps, no cool down lap, maximum heat soak etc. Mclaren use SRF in their F1 cars for a reason! |
