Alignment,Wheel balancing and Flashing car
09-23-2011, 05:29 PM | #1 |
71
Rep 1,285
what are the average prices for an Alignment,Wheel balancing and Flashing a car? please lmk what you guys have payed so i have an idea of what to pay more or less.
Another thing is what do you guys think as far as a flash? To remove the hesitation the gas pedals have curve air box? or something like that lol something with valves and tune car for another type of gas that idr Yes im a noob i have never modded cars performance wise so yeah any help would be highly appreciated thanks! |
09-23-2011, 09:11 PM | #4 |
319
Rep 1,023
Alignment: $150 give or take for a 4-wheel alignment from a reputable shop. Could vary a lot though. Probably triple that from a dealership, but I've never done that.
Wheel balancing: normally you only do that when you get new tires mounted, but any tire shop should do it for less than $50 total. Not difficult. Flashing: Not sure what options there are for 328i's, but head over to the engine mods subforum and see what people there recommend. You can probably just read up on what people do the most, and see what works. I know for the N54 engine (335i) it runs anywhere $500 - $1000 depending on which route you go. Hopefully that helped somewhat? |
09-23-2011, 09:27 PM | #5 | |
71
Rep 1,285
thanks again will read up! |
09-23-2011, 09:29 PM | #6 |
71
Rep 1,285
about the flash? this is what they told me at the shop
it removes the hesitation the gas pedal has so more responsive curve air box? or something like that i didnt understand it something with valves they change it or idk what.. and tune car for another type of gas that idr and they quoted me $400 wit everything |
09-23-2011, 10:29 PM | #7 | |
64
Rep 1,087
Drives: 2006 BMW 325i
09-24-2011, 02:06 AM | #8 | |
71
Rep 1,285
and Autowerke offered it to me..my only questions now is, is it worth it? would it decrease my mpg? |
09-24-2011, 08:28 AM | #9 |
NHTSA Nazi
28
Rep 1,983
Alignments vary greatly by region but are generally in the $100 - $300 range.
There are two ways of balancing wheels, the conventional way that costs about $15-20 per wheel and the 'road force balancing' that costs $25-30 per wheel. Road force balancing will actually move the tire on the wheel to balance the wheel as required. accordingly, it uses fewer weights and results in a much more precise balance. There is no 'flash' for a 328 that does much as normally aspirated engines benefit little from computer upgrades. All a flash does for a 328 is lighten your wallet. |
09-24-2011, 08:30 AM | #10 |
319
Rep 1,023
Only you can decide if it's worth it for you. Not sure of the hp gains of the software, but like I said earlier, there are probably dyno results posted in the engine modification subforum.
Gas mileage will be unaffected, at least on a scale large enough to notice. However, with more power you will probably drive it harder => worse mileage. |
09-24-2011, 10:39 AM | #11 | ||
71
Rep 1,285
Originally Posted by Hunter51092 Quote:
and yeah i guess i wont do the flash! ill just start looking into which quad exhaust like the m3 sedan is best for my car! |
