Who has a drivers side Recaro?
09-22-2011, 05:33 PM | #1 |
57
Rep 535
Hey Everyone
I've got a Pole Position I want to put on the drivers side of my E90. One question, how are people avoiding the airbag light? Do I REALLY news the OC3 module to cancel it out. The reason I ask is I see the OC3 module being advertised as a substitute for the passenger occupancy sensor. My passenger sensor will be staying though. (for those who have it) Is the airbag code something that the JB4 can delete/block? Thanks in advance! (I feel weird talking about my JB4, this is where all the Vishnu guys hang out, haha) EDIT: Forgot to mention, I tried searching but anything I found was both seats related, not just drivers side.
09-22-2011, 05:57 PM | #3 |
57
Rep 535
That makes sense, just like the E46.
Are there issues with pulling the drivers seat since there are side airbags, my E46 didn't have side airbags. Thanks!
09-22-2011, 06:00 PM | #4 |
138
Rep 2,731
cant answer that definitively but i would imagine the car checks the entire airbag srs system on startup and a missing component would trigger a fault light.
one word of caution, don't disconnect any components while the battery is connected, it will trigger a light that has to be reset. |
09-24-2011, 11:46 PM | #6 |
57
Rep 535
Update:
The seat is in (again, drivers side only) and I have both airbag and seatbelt lights. I reconnected the seatbelt wiring but it still won't recognize that I have my seatbelt clipped in. Either way, it looks like I'll need that stupid OC3 module thing after all.
09-24-2011, 11:50 PM | #7 |
483
Rep 10,309
Drives: A///MERICAN!!!
FWIW, the airbag light does not mean airbags won't go off in an accident. I live with my light, but if the fact that its on bothers you, then yea, you'll need a work around
09-24-2011, 11:59 PM | #8 |
57
Rep 535
Yeah, it just bothers me having it on. I think I might go the coding route. I should get a DCAN cable anyways. I hear people have luck coding it out.
09-25-2011, 12:35 AM | #9 |
112
Rep 4,771
Your light stays on because the car can no longer recognize your seat's side airbag.
Also be aware that the OC3 module turns your passenger airbag off. So it puts your passenger in a greater danger in the event of an accident. |
09-25-2011, 12:41 AM | #10 |
57
Rep 535
Thats why I'm trying to go the coding route. I like that because it just disables the light, not the airbag. I just don't know anything about coding. I think I'll just try to find someone in VA.
Forgot to add, the seatbelt light is confusing me though. That's plugged back in. Maybe it needs to be reset.
09-25-2011, 08:27 AM | #13 | |
NHTSA Nazi
28
Rep 1,983
Hint - nobody knows as you would have to crash test all variations of possibilities. In the OP's case, it is impossible to say how the airbag system may react. It may work as intended, it may not deploy correctly, or it may deploy incorrectly and kill him. Is that worth the snazzier seat? The airbag system is just that - a system. Making mods to it may mean that the system will compensate for the removed airbag or not. This is one unintended consequence that can be lethal. |
09-25-2011, 12:18 PM | #14 |
57
Rep 535
The light indicates that there is a fault. It doesn't change the way the system will operate in a crash though. Obviously, if it tries to fire the side airbag, it won't fire as it's not there anymore, but the rest of the airbags would function normally, as if nothing was changed at all.
It's a safety thing. If they made it so if there was a fault and the system shut down rather than reacting as normally as possible, look at how many people could be at risk. I remember on E46F there was a poll asking how many people had an airbag light on. It was around 40% IIRC.
09-25-2011, 01:24 PM | #15 | |
483
Rep 10,309
Driving the car through a large puddle, or being exposed to lots of rain Swapping steering wheels Removing the gauge cluster to replace light bulbs Aggressive and/or track driving Accidentally disconnecting an SRS component while hooking up electrical accessories, like an alarm or stereo Pulling a fuse for the SRS system while performing electrical troubleshooting. Bad seatbelt sensor in the belt receptacle (common failure) In my case it's because of the disconnected seatbelt sensor, which is built into the connector that supplies power to the motors, heated seats, etc...There is no occupancy sensor for the drivers seat because the car knows someone is driving. Keep in mind, at this point, I am not talking about the E9x chassis, but my original post does pertain to how the airbags work in all BMWs. I should've known better than to post in general section... |
09-25-2011, 05:21 PM | #16 | |
NHTSA Nazi
28
Rep 1,983
09-25-2011, 05:38 PM | #17 |
130
Rep 2,489
Drives: 2007 E92 SG 335i 6MT
pic of recaro in the car?
09-25-2011, 07:53 PM | #19 |
130
Rep 2,489
shes pretty.... pretty penny as well?
09-25-2011, 07:58 PM | #20 | |
169
Rep 12,680
Drives: like an asshole
09-25-2011, 08:05 PM | #21 | |
483
Rep 10,309
Yes, there are a few SRS faults that will result with the system not deploying the airbags. Replacing the driver's seat is not one of them. Because the car is being driven, the car assumes it has a driver, and driver airbags will be told to deploy, others depending on occupancy sensor readings. In the case of replacing his drivers seat, the only one that will not deploy is the one that's in the seat sitting in the garage. |
09-26-2011, 12:19 AM | #22 | |
57
Rep 535
Yes. Haha.
