Catless downpipes
09-22-2011, 02:09 PM | #1 |
8
Rep 52
Catless downpipes
I know this subject has been covered on here before and I did search however was just curious. I just installed ar design catless downpipes on my 335. I also have the jb4 installed and know that you have to turn on autoclear as far as codes go in order to take away the service engine soon light that is associated without having cats. But from what I read it also clears out the readiness codes of the o2 sensors which would make my car fail emissions. My big question is I remember reading that when it comes time for emissions testing there was a certain procedure that needs to be done in order to pass with catless. Was wondering what that was, or if it was impossible to do with catless downpipes?
I'm not worried about the visual inspection, it's just that if/when they plug it in the obd port, it will obviously fail if the readiness codes aren't set. Rather not have to take the downpipes off. I'm not in need of doing this anytime soon, as I have about a year left before testing is going to be needed. But want to prepare. I'm in the Ct area if that makes a difference as far as what procedures we do go through for emissions. For the record my car is a 2007. Or to save you guys some typing, if you can direct me to the link where i can get this info. |
09-22-2011, 02:58 PM | #2 |
103
Rep 3,177
you need a dpfix to pass inspection through obdII readiness check. the procede and jb4 have auto code clearing, but you won't pass emissions with that enabled.
to summarzie: -install dpfix -turn off auto code clearing -put some miles on your car with the above setup to set readiness |
09-22-2011, 03:12 PM | #3 | |
475
Rep 13,583
Drives: JB E92 335i
09-22-2011, 07:20 PM | #7 |
Some say...
239
Rep 4,296
Drives: Fresh
Yeeeaaah, no.
I have exhaust and an intake... |
09-23-2011, 04:18 PM | #13 |
Rep 17
http://www.ctemissions.com/expect-newer.html has info about emissions testing in CT. It seems like its the same as MD. I just got my emissions done and passed with DPfix. I have JB4 but DPfix just pins into your ECU, im not too sure how procedde works but im pretty sure you can install Burger motorsports DPfix with the procede in. Here is my post about the experience. http://www.e90post.com/forums/showthread.php?t=583725
JB4,BMS DCI, Raceland DPs, ER Chargepipe, HKS BoV, Powder Coated Stock Rims 8)
09-23-2011, 09:38 PM | #16 |
Supreme Allied Commander
3856
Rep 54,414
Drives: F80 M3
The readiness codes can take one or more driving cycles to complete and usually by that time your CEL would be back on again.
There is no way to force readiness on BMW like there is on VAG products. |
09-24-2011, 01:53 AM | #17 |
12
Rep 566
If you have a procede, you already have a built in dpfix (O2 signal modifier).
http://vishnutuningforum.com/viewtop...784fe195c0e1e0 But depending on how old your harness is, you might have to switch some wires around. The older harnesses supported this, the newer ones have it disabled. If you have a newer harness just reverse this update: http://www.e90post.com/forums/showthread.php?t=450494 |
