Procede at Altitude?
04-28-2007, 06:30 PM | #1 |
Since '75: 530i/733i/745Turbo/M5/M6/325iX/540i
7
Rep 191
I am planning to order Procede for my 335xi as soon as Vishnu confimrs that it has been tested on an xi model.
A related question is whether Procede adujsts to altitude automatically or if a different map is required for locations like mine (Boulder CO - 5400 ft). Anyone know? Shiv? |
04-28-2007, 06:48 PM | #2 |
96
Rep 2,587
Any regulated turbo system will mostly adjust itself for air density (due to heat, altitude, or other). People also claim the factory ECU will kick in another psi or two to make up for the pumping loses, and that should pass through in all the piggy back systems (TT, Xede, or Procede).
04-28-2007, 06:50 PM | #3 | |
95
Rep 1,760
04-28-2007, 07:01 PM | #4 | |
Rep 71
Bullsh!t, I live in Colo Springs, you are going to need the lower boost map or your engine light will come on under hard acceleration over 3rd gear.
04-28-2007, 08:03 PM | #6 |
7
Rep 191
Procede Tuning Clinic in CO?
04-28-2007, 08:17 PM | #7 |
44
Rep 428
04-28-2007, 09:38 PM | #9 |
1737
Rep 17,960
Drives: A Lot
Garage List 2018 Ducati Panigal ... [0.00]
2016 Mazda CX5 [0.00] 2017 Aprilia Tuono ... [0.00] 2019 BMW M2 Competi ... [0.00] 2015 BMW M5 Competi ... [10.00] 2016 Ducati XDiavel S [0.00] 2016 AMG GT S [0.00] 2011 Ferrari 458 It ... [0.00] 2017 Charger Hellcat [0.00] 2015 KTM Super Duke ... [0.00] 2016 KTM RC390 [0.00] |
We have customers who have tested the standard proced map up to 11000' above sealevel. There should be need to run a special map.
04-28-2007, 09:40 PM | #10 | |
Rep 71
what?
04-28-2007, 11:31 PM | #11 |
96
Rep 2,587
04-29-2007, 01:47 PM | #13 |
113
Rep 750
In my experience living at 5500ft, the turbo's struggle to make the same delta from stock at high rpm. The turbos are overspinning & generating more heat. They may make the same delta in torque, but in general they will peak a bit earlier at elevation & die a bit earlier as well. We found that water injection tends to make it a bit more efficient & give back some of the losses at high rpm. Has anyone tried water on a 335?
05-02-2007, 04:37 PM | #14 | |
1737
Rep 17,960
Drives: A Lot
shiv |
05-02-2007, 06:55 PM | #15 | |
Rep 71
I needed the lower boost map, I live in the Colo Sprgs.
05-03-2007, 06:23 AM | #17 |
Rep 71
At first it was sparatic, but for some reason as the weather got warmer and the engine hit around 230 and I punched it, when I hit about 5th gear it would go off all the time. I downloaded the new map v1.45 lbt and it hasn't happened at all. There is no difference in power, the car is a frikin monster.
