Steering Wheel Vibration Solved!
09-20-2011, 01:09 PM | #1 |
12
Rep 215
Drives: 335i Coupe
I've been having a steering wheel vibration for a few months and it started when I got a new set of runflats. I went from Bridgestone to Michelin and when my speed reached between 42-52 mph, there was a definite slight shimmy in the steering wheel. Also, the vibration appeared to be more apparent when the tires were cold.
Had the tires road force balanced checked the rims for balance Actually replaced one rim because it was bent, helped the situation, but didn't solve it. Had Michelin replace the two front tires (no charge), still no change. Finally, a BMW tech replaced the Thrust Arms and Bushings and now she drives tight as can be. Just thought I'd pass that on
e92/Black Sapphire/Coral Red/Aluminium Trim and Pedals/Sport/Luxury/Nav/Keyless/Ipod Adapter/6MT/Sirius/Turbo Tuner
09-20-2011, 02:33 PM | #2 |
153
Rep 3,730
Congrats you got it solved. I'm getting some vibration above 65mph, balanced tires helped but I'm thinking of replacing the control arm and bushings with M3 bits.
2008 BMW 335i e90 - Sold - Rob Beck Turbos / PROcede V5 / Aquamist HFS-4 / AR Downpipes / AE Exhaust / ER Comp FMIC / ER CP / TiAL BOV / Custom Intake / RPI Scoops / Quaife LSD / Swift-Koni Coilovers / DSS HS / Morr VS8.2 Sig Black / Michelin PSS / P3 Boost Guage / M3 body / M3 steering wheel / Adam's Rotors / Hawk HPS / SS lines /
09-20-2011, 02:51 PM | #3 |
186
Rep 339
Drives: 07 e90 335i
Thrust arms I get...which bushings were replaced?
Edit: actualy do the new thrust arms come with the bushings? The bushings alone are 80 dollars and the whole arm is 90 dollars. We've been trying to figure out the vibration at speed on the pass side. We did the same as you, wheels/tires alignment but it still vibrates. Also for that price I might just go with the M3 bits. Last edited by MicaCeli; 09-20-2011 at 03:03 PM.. |
09-20-2011, 11:05 PM | #5 | |
42
Rep 659
Thrust arm = front control arm? I'm not sure it comes with bushing like they sell the m3 kit. |
09-21-2011, 10:50 AM | #7 | |
186
Rep 339
Drives: 07 e90 335i
09 Tension strut with hydraulic mount, left 1 31126769797 $122.04 09 Tension strut with hydraulic mount,right 1 31126769798 $122.04 10 Set rubber mounting f pull rod 1 05/2011 31120393540 $98.93 10 Hydrobearing 2 31126763719 You could get these (stock but with Rubber Bushings) http://hpashop.com/product.sc?produc...categoryId=175 Or the M3 ones http://hpashop.com/product.sc?produc...categoryId=175 |
09-21-2011, 11:34 AM | #8 | |
748
Rep 4,429
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
09-21-2011, 02:31 PM | #10 |
8
Rep 40
id get an alignment after balancing the tires and try to diagnose the car for worn suspension components by reading the alignment angles. a good alignment specialist could have saved you time. good to hear you fixed the problem though.
09-21-2011, 02:41 PM | #11 |
12
Rep 215
Drives: 335i Coupe
I had my car in twice before BMW replaced the control arms and bushings. They may have checked them but they didn't look damaged. There was some info on their system that lead them to change the arms and bushings. Glad they did 'cause I was beginning to lose the love for my car!
09-21-2011, 02:42 PM | #12 |
12
Rep 215
Drives: 335i Coupe
Road Force Balancing is the way to go. It does make a difference.
09-21-2011, 03:29 PM | #13 |
16
Rep 261
09-22-2011, 01:29 PM | #14 |
BimmerPost Supporting Vendor
31
Rep 326
09-22-2011, 09:25 PM | #15 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Have a look at these thrust arms with HD bushings:
http://www.hpashop.com/product.sc?pr...categoryId=175 Or just the thrust arm HD bushings only: http://www.hpashop.com/product.sc?pr...categoryId=175 The althernative would be the M3 thrust arms, even higher durometer bushings. |
09-22-2011, 11:31 PM | #16 | |
16
Rep 261
09-22-2011, 11:44 PM | #17 |
68
Rep 639
Drives: 11 E90 328i
Were your front tires wearing funny before your fixed this?
09-23-2011, 12:25 AM | #18 | |
42
Rep 659
09-23-2011, 08:29 AM | #19 |
PSI
15
Rep 349
[QUOTE=fefo25;10474809][QUOTE=HP Autowerks;10474263]Have a look at these thrust arms with HD bushings:
[url]http://www.hpashop.com/product.sc?productId=305
2011 335d, M-sport, Alpine White, Nav
09-23-2011, 10:48 AM | #20 |
3847
Rep 54,376
Drives: F80 M3
05-27-2013, 10:31 AM | #22 | |
17
Rep 265
I really am loosing my desire for the car with this annoying trait. Any suggestions or should I tell them to replace them regardless of what the mechanics think? |
Tags |
steering wheel vibration |
