Akebono Pads - Bed in or not???
09-20-2011, 09:20 AM | #1 |
29
Rep 425
Just installed new OEM rotors front and back with Akebono pads. I've read in the forums both to bed in and not bed in. Anyone have anything official on this. Was thinking with new rotors bedding wasnt necessary. Initial bite right now sucks but know will get better in the next 500 miles.....thoughts?
09-20-2011, 02:02 PM | #2 |
29
Rep 425
Guess I found the answer: http://www.tirerack.com/brakes/tech/....jsp?techid=85
No bed-in procedure needed for Akebonos..... |
09-20-2011, 05:10 PM | #5 |
253
Rep 7,089
Drives: '06 AW 330xi
Pretty sure all pads need to be bedding in to get the full potential out of them.
09-20-2011, 08:30 PM | #6 |
24
Rep 1,244
09-22-2011, 01:28 PM | #7 |
29
Rep 425
Should have just done this from the get go but called Akebono Corporate HQ and they said there is no bed in process necessary for these pads.
I can certainly see a need for this with used rotors though.... |
09-23-2011, 08:11 AM | #9 |
253
Rep 7,089
Google the procedure. Basically you do some hard stops, just enough before ABS kicks in, and wear away a layer of pad material so it "forms" to the rotor surface.
On new rotors AND pads, it will help get some oil/residue off that is on the rotors from the factory. |
09-23-2011, 09:28 AM | #10 | |
24
Rep 1,244
Used or new, I would do it to ensure the highest possible performance. I know most manufacturers say it isn't necessary...but that's probably because most people don't how to do it properly. |
09-23-2011, 08:58 PM | #11 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
The initial bite is not as good because the pads and rotors aren't burnished yet. |
